Author Subject: s16 supercharged
tarret
can anyone tell me will the rotex charger for the gti 6 fit the s16?
Posted 1st Jan 2011 at 19:57
yup.
Posted 1st Jan 2011 at 22:32
tarret
sweetSmile
cheers mate
Posted 4th Jan 2011 at 02:35
nxa
I was wondering about this too.
Is it a straight bolt on like the GTi6 though?
I remember reading that you may need a Gti6 sump and different engine management for the setup to work.
Can anyone confirm this?
Posted 4th Jan 2011 at 02:53
allanallen
I think you'd need the sump and the engine mount offthe six engine at a minimum.
You'll struggle using the six management but I guess it's possible. You'd have to make something up for the cam sensor and attach the coils somehow. Mr schofield can re-map the s16 ecu so it may be possible to use the standard management???
Al
Facebook
Posted 4th Jan 2011 at 03:05
S16 has a cam sensor.
Posted 4th Jan 2011 at 03:24
miles
And if a A/C model will have the right engine mounting, Only the non A/C ones will need that along with the Alloy sump.
Be intresting to see what power it could make the C/R is lower on them as std
www.pugracing.com
Posted 4th Jan 2011 at 03:47
not much mind, only 0.4, pesky cast iron manifold might hold it back Hmm Miles can do a proper job there though Smile
Posted 4th Jan 2011 at 03:49
dan_s16
Stop giving me ideas that I can't afford Sad Cry
icetto
I wanna do this on my 180 but those parts from the 6 someone mentioned earlier are not in SA.
Another question: Is there a way to keep your Aircon when doing the supercharge conversion?
Jy dink jys cooler as ekke
Posted 7th Mar 2011 at 13:17
rallyeash
yes, i believe "Toby" did a s/c conversion and kept the air con.
309 3dr K20 Type R
Posted 7th Mar 2011 at 13:30
Yes, you will need to convert to an electric power steering pump...Yes
Stan.
Posted 8th Mar 2011 at 04:37
icetto
Stan.
How does that differ from the standard one?
So what features did the SC 306 guys have to give up to do this conversion?
Posted 8th Mar 2011 at 11:36
anth
Most dump the aircon, But as said if you want to keep it you need electric PAS so you can get rid of the normal pump which runs on the crank.
Believe the 106 uses it so could take it from that.
Posted 8th Mar 2011 at 12:13
rallyeash
yeah 106 has an electric pump
309 3dr K20 Type R
Posted 8th Mar 2011 at 12:43
icetto
There are no 106s in SA so any other cars I could try?
Posted 8th Mar 2011 at 13:02
MCH_GTi6
formerly mch
mr2 ?
Team Moonstone� Ph3 GTI6
Team Rallye
Posted 8th Mar 2011 at 13:24
icetto
MCH_GTi6 wrote:
mr2 ?
Any specific year model? MR2s are scarce in general here.
How about any Opel,Hondas, VW or Toyotas? They are all over our roads
Posted 8th Mar 2011 at 13:55
rallyeash
vauxhall astra mk4, zafira
309 3dr K20 Type R
Posted 8th Mar 2011 at 16:38
icetto
Ok so how do I go about in getting that powersteering from that Astras or Zafiras?
Scrappy? Or can I just get that powersteering components?
Posted 8th Mar 2011 at 17:58
felixthecat
Some renault kangoos, clios and megane with the 1.5 dci (diesel) engine have also electric power steering. But they differ between the years, some have one others not....
306 Gti6 Cherry Red Supercharged Smile
Greets from Germany....
Posted 9th Mar 2011 at 02:34
