Author Subject: cam pullies
JWP EFi
Turbo Legend!
Happy new year all.
can anyone tell me if the early adjustable (3 bolt) cam pullies will fit onto the later RS engine? (my engine is from 2002 xsara vts) As i stupidly removed mine without marking them. I also want the early ones so i have some form of minor inlet adjustment
cheers
Posted 1st Jan 2011 at 17:45
late ones are adjustable too.
Posted 1st Jan 2011 at 18:25
JWP EFi
Turbo Legend!
ok, seeing as i didn't mark the position of the pullies, how do i go about setting the cam timing again?
Also is it true that the later type are prone for slipping?
Posted 2nd Jan 2011 at 18:00
naah, its the early type that are known for cracking if over tightened.
to set the timing you just put the pins in with bolts slack, tension belt then tighten central bolts.
Posted 2nd Jan 2011 at 18:33
