Author Subject: Standard Headunit wiring
vernam616
Right ive recently reverted back to my standard phase 3 slot cd player
Now the problem is it will not come on and off with the ignition, only when pressing the on/vol button manually
Easy fix i think?
Ill swap the fuse position up one.....
Fail, the radio now comes on and off whenever i switch the ignition, however seems to have dropped its permanent live, by asking for the code everytime i turn the car on Angry
All cabling is standard and hasnt been tampered with, does anyone know why its doing thisCrazy
Also very confused as to why my steering wheel remote control wont fit into the back of it ?
Any help appreciated
Dan
Audi S3 Black Edition
Posted 31st Dec 2010 at 23:55
The lead for the stalk has the wrong connector on it. You will need a phase 3 stalk.
The other problem can be answered by a search as I recall it being asked before by Wattsy when I lent him a PU2294-A for his phase 2 and he had same problem.
Posted 1st Jan 2011 at 16:40
vernam616
Thanks for the help Jon Thumbs up
Posted 1st Jan 2011 at 17:19
chrisd306
Ive got the same problem but with an aftermarket stereo (not using stalk) no matter what i do it will not turn off an on with ignition?
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 2nd Jan 2011 at 11:01
maxdrz400
try swapping the permanent live with the ignition live. one should be red one should be yellow sometimes theyve got little plugs on the wires that can be swapped easily and should only take about 5 minutes. hope this helps
Posted 2nd Jan 2011 at 23:08
aaron6
Some don't have a temporary live. My six has two permanent lives.
Posted 3rd Jan 2011 at 04:23
vernam616
Its a standard stereo with standard wiring, Ideally you shouldnt havnt to start cutting the loom on a standard set-up
Posted 3rd Jan 2011 at 05:01
maxdrz400
is the head unit the correct year for your car if not peugeot may have changed the wiring slightly. and i didnt mean cut the wires generaly theres little bullet like plugs on the wires themselves. is the headunit new? if not did the original owner swap wires around some of the wiring iv seen in the past nothing surprises me anymore.
and a car with 2 permanent lives ive never heard of that before is all the wiring standard?
Posted 4th Jan 2011 at 01:39
vernam616
I presume the headunit is correct for the year but not correct for the spec (with it being a Rallye), there is no bullet connectors on standard connections, these only come on aftermarket harness's
All the standard wiring looks pretty untouched
Posted 5th Jan 2011 at 21:38
