displaying posts 1 to 25 of 28
Author Subject: Rear demister not working
madgerald
I've just bought a new GTi-6 and the rear demister isn’t working Sad
When the button is pressed there is a “click” from the fusebox area but the button doesn’t light up or the rear screen clear
I just want someone to tell me it is simple to fix!
Thanks if you can help Smile
Posted 30th Dec 2010 at 01:47
simonjames
Is there any illumination on the switch at all?
MY EBAY ITEMS
07943066306
Posted 30th Dec 2010 at 22:53
madgerald
It flashes momentarily but doesn't stay on Sad
Posted 31st Dec 2010 at 01:25
james_geldart
its the fuse/relay - had this on mine last winter - thugpuggin helped me out so he'll know which one you need
Recommends:
'mechanical_repairs' - Leicester
'miles' for suspension & Grp N/A goods
Baker BM Mounts
Posted 31st Dec 2010 at 03:13
madgerald
I will ask him when he collects my old car LOL
Posted 31st Dec 2010 at 13:55
misschief
Mine does the same, any further info on which fuse?
Posted 1st Jan 2011 at 05:47
Phase 3 fuse 7 30A and 22
Phase 2 fuse 5 and 27
The relay is the large Orange one with 9619879180 on it.
Posted 1st Jan 2011 at 16:52
misschief
Magic, cheers mate.
Posted 1st Jan 2011 at 17:20
madgerald
Thumbs up
Posted 1st Jan 2011 at 22:30
misschief
Can I get the relay from halfrauds? Might pop down this week.
Posted 4th Jan 2011 at 07:28
will130787
Yes, although you might find they only have a 30 amp rather than 25 Smile
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 4th Jan 2011 at 15:24
Excellent info Cool
Mines dodgyNinja
Smile
Posted 13th Jan 2011 at 02:25
misschief
Went to halfrauds, guy behind the parts counter said they don't stock them. I've checked the fuses, they're both fine. One thing I did notice though, how the f*ck to you taker the existing relay out? Don't want to break it in half but I tried squeezing, turning, cursing etc but it was stuck.
Posted 16th Jan 2011 at 05:21
chrisd306
Just have to wiggle it out, will be tight as probly never been out before!
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 16th Jan 2011 at 06:01
mike rallye
i got this fault with my rear demister,it wont light up on the switch but will light up when the lights are on.but it doesnt stay on.i have checked me relay and found out it has failed and burned the connecter out were the relay goes into.
so what is that part called that the relay goes into. is it called a base?
any info would be gratefull
Posted 27th Jan 2012 at 19:08
mik
Do you mean the contacts in the relay panel itself? In that case you would need to clean up/re-solder/replace the burned out contacts.
Good idea to pull all relays and fuses one at a time, clean contacts as they get corroded with cars sitting outside in the weather all the time and things being generally wet corrosion builds up, which increases resistance, which makes the contacts and relay get hot, and eventually burns things out. Even just unplugging and replugging helps contacts conduct current better as it scratches the contact metal slightly cleaner.
First step to check if correct relay fitted: my rear demister only worked if button held in with finger, when releasing it light went out. Turned out a PO had replaced the orange relay with a green one (standard on/off relay). A replacement orange one (correct orange relay has 10 - 12 minute timed delay) fixed the problem.
Cherry Rallye SOLD
Posted 23rd Feb 2012 at 15:37
Ed_van_dijk
Where can I get one of these said orange relays?
Astor 6
Posted 17th Feb 2013 at 11:36
mik
I got mine second hand off here. Or try Pug - can't be that expensive.
Cherry Rallye SOLD
Posted 17th Feb 2013 at 16:29
Ed_van_dijk
I have changed the relay which cured the problem used the demister about twice and it's stopped working again, I assume it's the relay again, anything else I should check before putting another relay in it?
Astor 6
Posted 18th Feb 2013 at 21:25
Ed_van_dijk
Just went and pulled it out and it has melted number 3 termal again
Astor 6
Posted 18th Feb 2013 at 21:31
Got a few if needs be.
Posted 18th Feb 2013 at 21:50
Ed_van_dijk
Even if I just changed it to another new relay it will probably just melt that one too?
Astor 6
Posted 18th Feb 2013 at 21:53
Was the relay you fitted second hand?Dunno
If so could have been used alot,I would try newThumbs up
Posted 24th Feb 2013 at 11:16
£25 new
Posted 24th Feb 2013 at 11:29
£25 new
Ouch.Thats from Pug?
Need one for mine too,second hand one has lasted a while thoughSmile
Might search relay part numbers see if available anywhere else except PugThumbs up
Posted 24th Feb 2013 at 13:47
