Author Subject: inlet cam timing?
bobdylan_55
Hi people
Just wondering if anybody has any information on timing for a standard gti6 inlet cam?
Id expect it to be about 15 BTDC and 50 ABDC?
cheers
309 GTi6-T
Posted 28th Dec 2010 at 20:33
allanallen
I've asked this before and no-one seems to know. From checking a few now I'd say it's somewhere around 0.55 mm lift at TDC working with the standard timing holes. Not sure of the BTDC and ABDC though as ive only ever used the lift at tdc method when doing cam timing.
Facebook
Posted 28th Dec 2010 at 21:39
bobdylan_55
Standard specifications are 205 deg. @ 0.050" lift and 0.395" but its the opening and closing timings i need Sad
309 GTi6-T
Posted 28th Dec 2010 at 21:40
cwspellowe
considering a cheeky regrind?
Bye bye Sundance Kid Sad
Posted 29th Dec 2010 at 17:16
bobdylan_55
nope, its for a uni project investigating inlet manifold design on forced induction applications. Basically could you leave the inlet valve open much much longer as you are forcing the air in?
Need the inlet timing so i can figure the compression pressures at the point that the valve closes.
309 GTi6-T
Posted 29th Dec 2010 at 17:19
cwspellowe
I'd assume so to a degree, PeterT's cam regrinds provide longer duration instead of higher lift. Maybe worth sending him an email?
PeterT website clickey
Some useful info on his site about the 4RS engine too Smile
Posted 30th Dec 2010 at 02:57
