Author Subject: driveshaft question
speedo306
Hi i have a gti6 with a 1.8 gear box i was getting a vibration when driving and realized the inner cup was worn bought a new gti6 axle from euroshaft and fitted it i just gave it a test drive and am still getting a vibration. what can be the possible cause of my problem?, rims are fine.Unsure
RJ
Posted 28th Dec 2010 at 07:54
CUJ
Could be warped brake discs, a fairly common cause of vidrating/juddering.
340 horses
Posted 28th Dec 2010 at 13:47
speedo306
If the brake disc is warped wouldn't you feel it when you mash the brakes?
RJ
Posted 28th Dec 2010 at 20:22
mickye
Can you explain the vibrations a bit more i.e. do you get them at certain speed, certain loads, does the gear knob vibrate too, does the steering wheel vibrate.
I have had a vibration problem recently not coming through wheel but the whole car including gearstick, it turned out that I need 2 new driveshafts.
there is another post on the forum somewhere if you search with all the details which may help you
Posted 6th Jan 2011 at 16:49
