Author Subject: induction with sandard box?
mattgti6phase2
hi everyone and MERRY XMAS to you all. i have done a quick search and havent seen what im about to ask pop up.
right, i have a green cotton filter in my standard 6 airbox after fitting this some time ago now i have found that the car was and is more responsive when you stamp on the loud pedal.
then i had a thought ........ lets see if i can make the old girl suck a bit more?? what i did was remove the small secondary air box and capped off the hole for it. I then removed the main pipe from the top of the air box leading to the slam panel because in standard situe i noticed the there is a gap between pipe and box which must be about 15mm.
anyway i pootled down to my local exhaust place and made a stainless steel sleeve which i flared to fit tight into the top of the box, we then spot welded it into place to make sure of no movement. We then flared the other end so that it would fit extremely tightly into the existing cold fit and buzzed a bead of silicone round to make doubely sure it was all air tight.
Now we have no gap and a very air tight feed. when the car is ticking over you can feel the air feed sucking, and when you twist the throttle it really sucks alot of air with a very subtle induction kit noise. so i took the car for a spin and hey presto even more response when you hit the loud pedal.
But today after a conversation with a fellow forum member he suggested cutting a hole in the cold air feed roughly where the bit sits closed for even more air. his reason of thinking was due to the feed pipe being situated under the grill.
IMO i think this could be an excellent idea but what do you all think? as said above she already sucks alot of air with the mods i have made to the box. If this will aid induction anymore then im game!!!!
sorry for the essay, Im not really a believer in iduction kits really unless you have a proper enclosed one with good air supply e.g down by the fog light. However with our terrible english weather i would be scared in sucking up water.
Thanks in advance guys Smile
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 25th Dec 2010 at 02:05
jimbamboon
This is weird because I cut an opening in my existing cold feed above the grill today, can't really say it's made much of a difference but I have been thinking about ways to improve the standard air feed recently, not sure what you mean by the small secondary airbox though
clicky code for my benefit
Posted 25th Dec 2010 at 02:29
mattgti6phase2
as you stand looking over the engine bay so the airbox is to your right look down and to the left of the air box and you will see a small secondary air box. i assume by routing the air on a longer journey it quietens the sound of induction and doesnt breathe aswell. have it gone Smile
5 x a 306 owner!
Posted 25th Dec 2010 at 02:34
jimbamboon
Is that the airbox resonator? what purpose does it serve?
Posted 25th Dec 2010 at 02:49
mattgti6phase2
That's the one. The purpose of it is stated above Smile
5 x a 306 owner!
Posted 25th Dec 2010 at 03:05
Done the same to my airbox,removed the resonatorWink
Also I was thinking about the forced induction feed,so I have cut the end off the snorkel intake on an angle just above the slam panelSmile
So now once the cars moving air should hopefully be pushed into the airbox between the bonnet and grille,instead of it just being sucked from behind grilleBig grin
Posted 25th Dec 2010 at 03:32
mattgti6phase2
Im hoping to achieve this aswell by cutting the snorkel back to Smile the more air the bet IMO. Do you have any pictures of how you have cut yours??
5 x a 306 owner!
Posted 25th Dec 2010 at 08:39
jimbamboon
IPhone clicky took ages
Just carefully used a stanley knife to cut out the section, haven't put any mesh in yet
Posted 25th Dec 2010 at 12:51
joevts
not sure about the 306 but on the xsara there are some holes in the slam panel directly below the mouth of the scoop which will obviously disturb the airflow coming in thru the grille, so i screwed a bit of stainless plate onto the back of the scoop where the mesh screws on to deflect the airflow straight up into the scoop, and there were 4 holes about 10mm diameter in the scoop where it goes down the back of the rad, i taped them up to stop it sucking in warm air, and finally i made a custom airbox out of aluminium, very similar to the OE box but to fit over a K&N 57i and shaped to send the air spiralling round the filter instead of straight onto one side of it.
Posted 25th Dec 2010 at 14:43
mattgti6phase2
That picky looks like what I want to achieve jim. Any good though??
Pretty much the same on the 6 Joe. What does yours go like with what you have done?
5 x a 306 owner!
Posted 25th Dec 2010 at 22:21
Will take some next time I'm out there Wink
Posted 26th Dec 2010 at 01:18
joevts
seemed to make a big difference over the open filter, but i did tighten the throttle cable at the same time. also made it nearly as quiet as the OE box, which disappointed me. it's off now though, i missed the noise and don't see the point in cold air feeds when it's -7 outside LOL i'll be putting it back on when it warms up a bit.
Posted 26th Dec 2010 at 18:45
jimbamboon
As I said not sure whether it's made much difference as i also tightened the throttle cable at the same time too, but it's definitely worth giving it a go, car is running sweet at the moment!
Posted 27th Dec 2010 at 00:12
will130787
Get yourself an enclosed kit and feed as we said or Stanley knife/jigsaw a hole in the feed pipe bud Smile
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 27th Dec 2010 at 02:39
mattgti6phase2
Going to set mr Stanley to work once I get in from work if it's still light and hopefully it will make a difference Smile
5 x a 306 owner!
Posted 27th Dec 2010 at 19:41
Have cut mine right off at an angle to face down to gap between grille and bonnetWink
Also rivetted a small plate on front panel just in case any nice cold air trys to go down there and not into the air filterLOL
Posted 3rd Jan 2011 at 02:41
mattgti6phase2
thats a really good job Smile have you found an improvement?
i have now done mine and found the car was hesitant for a day or so but now it seem to pull harder and pick up better.
did you also experiance this?
5 x a 306 owner!
Posted 3rd Jan 2011 at 17:14
I wish I could tellRazz
Cars on axle stands with no suspension fitted ATM!LOL
Posted 4th Jan 2011 at 02:08
mattgti6phase2
haha!! bad times. what are you doing to it?
5 x a 306 owner!
Posted 4th Jan 2011 at 02:28
Got a thread going in Projects forumWink
Posted 4th Jan 2011 at 02:57
mattgti6phase2
I will take a peek
5 x a 306 owner!
Posted 4th Jan 2011 at 18:35
