Author Subject: Lowered or standerd
daytime-6
My car is lowered on the font at the moment,but was thinking of putting my car back to standerd , but if I put standerd springs back on and put updated shocks front and back would it make the handling just as good as if I had it lowered all round or would it be worse???
Team Astor
Posted 14th Dec 2010 at 18:30
paul_13
I have always found cars handle better at standard height with uprated shocks etc.
Leave it as the height it should be, lowering cars just throws the geometry out.
How low are you talking about going?
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 14th Dec 2010 at 18:33
daytime-6
Na I was thinking of going back to standerd height and just uprating the shocks
Team Astor
Posted 14th Dec 2010 at 19:00
paul_13
Crack on Smile
You have 'give' in your suspension for a reason, not having much will throw you off the road from hitting teh bumpstops.
Posted 14th Dec 2010 at 19:02
daytime-6
Yer it's to hard when going over bumps or whn I hit potholes, it just makes nasty noises which I don't reali want lol,Whts the best suspension kit to go for ?
Team Astor
Posted 14th Dec 2010 at 19:10
paul_13
Stay away from cheapy kits obviously.
Do a search mate will bring up loads of answers, search through google if it don't bring any thing up.
Posted 14th Dec 2010 at 19:15
daytime-6
Na Ive had cheap kits on my old car n it was horrible to drive,will go for sumit like spax or bilstien or koni,cheers for the help
Team Astor
Posted 14th Dec 2010 at 19:28
rallyeash
bilsteins would be a good shout mate Smile
309 3dr K20 Type R
Posted 14th Dec 2010 at 20:10
daytime-6
ive already got bilsteins on the front but i thnk there just replacment ones,i think mine are the black one but wana get the yellow ones would be alot better
Team Astor
Posted 14th Dec 2010 at 23:23
petey
I'm running Bilstein B8 Dampers (the yellow ones) along with Eibach 30mm springs and the rear is lowered to suit. I definately recommend it as a good fast road set up. I've found that I now get less body roll, better damping and still have enough suspension travel to cope with our bumpy roads Thumbs up
High Boost Supercharged 306 GTI6
Alfa 147 GTA
Posted 4th Jan 2011 at 14:40
