Author Subject: on/off bulbs
j1mmy
have a small issue but its one of them that really get to you! Smile
I have a ph2 car with ph3 headlights and the issue is the dipped beam bulbs seem to keep moving out of they're slot so when driving at night one minute i have two lights the next i have only one or even sometimes none an end driving sidelights n fogs! Angry its doing my head in now and would imagine doing people who i'm following or coming towards me heads in to lol!
Has anyone had this before?
Also what bulbs would you recommend?
now a very happy an proud GTi6 owner! Big grin
TEAM: Blaze phase 2
TEAM: Off the road for now Sad
Nimrods going up 4 sale will be available in the next week! Pm if interested.
Posted 13th Dec 2010 at 04:20
dan_s16
Are you saying that the bulbs keep sliding back out of the reflector?
If so they should be held in with a metal spring clip to stop them falling out:
No 3 in this pic (not a 306):
Posted 13th Dec 2010 at 05:41
j1mmy
thats what i'm saying and they are held in by the spring clips! I might see if i can bend the clips a little bit as they do seem a little loose like they're not doing they're job!
TEAM: Blaze phase 2
Posted 13th Dec 2010 at 08:08
smithers
Is it possible to fit the wrong bulbs, i.e. H4's instead of H7's?? Confused
1997 Black GTi6
smithers205 at hotmail.com
Posted 13th Dec 2010 at 20:07
j1mmy
it has H7's in it but something just doesn't seem quite right about the fitting! Maybe the light units are knackered or been bodged?
Are both the dipped and high beam bulbs H7's?
Cus the high beam bulbs are blue and don't really make anythin brighter!
TEAM: Blaze phase 2
Posted 14th Dec 2010 at 01:07
j1mmy
right this problem is really bugging me now an has got slightly worse!
So checking it out today i had solved the bulbs moving by bending the pins a little which kept the bulbs in place but now i have a problem i might of missed before, the driver side light wont work on dipped beam and the pins on the back of the bulb had broke away the wires are burnt and the plastic cover on the terminals has melted! The passenger side dipped works but i noticed it smoking and was very hot! I am very puzzled will it be a short some where? Where should i start? I'm thinking of putting it back to standard ph2 headlights would that help?
TEAM: Blaze phase 2
Posted 30th Dec 2010 at 04:57
Rich E Forum Admin
What bulbs do you have fitted? It sounds like they're drawing too much current and melting the wiring and connectors.
I'd take the lights out and have a good look at them to see what the problem is.
Posted 30th Dec 2010 at 05:22
j1mmy
nothing special just normal H7 12v 55w bulbs! Any idea what would cause them to draw to much currant? It looks like it has done so on driver side i have a funny feeling its killed the wiring to cause when i put a perfectly working bulb in it wouldn't come on Huh? i dont know much when it comes to electric's any help will be very appreciated thanks!
TEAM: Blaze phase 2
Posted 30th Dec 2010 at 08:24
j1mmy
does any one have an idea on this? Why would the wires get hot?
TEAM: Blaze phase 2
Posted 30th Dec 2010 at 21:31
