Author Subject: Timing Figures urgently needed
3dmotorsport
Does anybody know the timing figures for a 306 rallye with:
272 inlet and 278 exhaust cams?
any help appreciated!
Posted 12th Dec 2010 at 22:50
depends who made the cams, and also how much space you have in the pistons.
Posted 12th Dec 2010 at 22:52
3dmotorsport
haven't got a clue who cams are made by, the head gasket has been replaced, only to find non- standard cams and I am having trouble trying to figure out who they are made by!
stampings on inlet cam:
272 05H58 0031
exhuast cam:
278 15H47 0925
Posted 12th Dec 2010 at 23:54
Rich E Forum Admin
They look like the standard markings. Are they in three rows on the non-driven end of the cam?
Posted 13th Dec 2010 at 00:01
3dmotorsport
yes they are!
result then, any ideas on timing figures?
Posted 13th Dec 2010 at 00:04
Rich E Forum Admin
Standard timing then! Just pin them up using 6mm pins into the timing slots in the pulleys and the head.
There should be a hub that goes into the key way in the cam and into the pulley to give the correct timing position.
Oh, and as it sounds like you haven't timed the engine up before stipping it down check the crank pulley hasn't slipped and allowed the timing hole to move. These pulleys have a habit of doing that.
Posted 13th Dec 2010 at 00:08
