Author Subject: stiff gears
dan164
just had my timing belt done. my cars done about 80 miles and now the gearstick is absolutely solid to move. is their any comon parts of the linkage to fail? it was a little stiff a couple months ago so i just sprayed the pivot joint which looks a nightmare to change with wd40 and it worked ok. ive not had a chance to get under it so any ideas?
Posted 12th Dec 2010 at 17:24
Rich E Forum Admin
Possibly low on oil or has the wrong grade of oil. These gearboxes do get very stiff under those circumstances.
A heavily worn gearbox mount can cause this too.
Is it easier to change gear with the engine off?
Posted 12th Dec 2010 at 18:33
dan164
it has a small leak from a driveshaft oil seal but no crucnching or anything and its not lost much oil. its the same with the engine off and it really feels like the linkage. il need it over a pit at work for a good look
Posted 12th Dec 2010 at 18:48
chrisd306
if you need a box mate ive got 1 lying in the garage.
only time ive had stiff gears was when my clutch plate had cracked, but that was form harsh driving, but the gearstick still moved freely but was hard to select gears.
the d turbo is still running spot on mate!
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 13th Dec 2010 at 01:21
dan164
good good that thing will go to the moon and back and not miss a beat. found the problem, the pivot bolt that bolts to the subframe, that bush is seized, when the bolts tight gears are solid, bit of advice for people with similar problems, take the bolt out and put some lock tight on it, tighten it up then loosen it a quarter turn, you can move it with your pinky!
Posted 14th Dec 2010 at 16:37
bobdylan_55
if they bodged the timing belt, might have dropped the engine on the drivers side but not taken the linkages off and could of bent them?
worth a check
309 GTi6-T
Posted 14th Dec 2010 at 16:45
scottycollard
Does anyone know which oil to use in the gearbox
Posted 15th Dec 2010 at 18:37
anth
Get it from peugeot
Posted 15th Dec 2010 at 21:19
rallyeash
75w80 gear oil.
2 litres will surfice.
309 3dr K20 Type R
Posted 15th Dec 2010 at 21:35
gtisid
sounds like a linkage problem, gearbox oil is important as the other stuff makes the gearbox tight when the oil is cold. pug stuff is p*ss thin but these gearboxes love it. as i said though it does sound like your linkage could be bent from the cam belt change. dropping the cam belt side of the engine to gain access to the belt and may have consequently bent your gear rods!!! or maybe even busted your gearbox mount
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 15th Dec 2010 at 22:03
rallyeash
already been sorted
309 3dr K20 Type R
Posted 15th Dec 2010 at 22:07
