"if in doubt flat out"Breaking 206 gti
| Author | Subject: airbag question phase 2.5 |
pug-gti-6
Regular Location: welshpool Registered: 21 Apr 2008 Posts: 254 Status: Offline |
I have just replaçed my seats and connected the airbags up, i dont have a light on the instrument panel. how can i find if the airbags work? ive got a momo wheel so the driver airbag is disabled. Since owning the car there has been no airbag light. the ecu is in plaçe. is there a relay by the fuse box for the airbags?________________________________________ "if in doubt flat out"Breaking 206 gti |
cooper666
Senior User Location: doncaster Registered: 27 Nov 2009 Posts: 778 Status: Offline |
have you checked to see if theres a bulb in the instrument cluster for the air bag________________________________________ clio r27ps3 id:cooperkloe |
pug-gti-6
cooper666 wrote: have you checked to see if theres a bulb in the instrument cluster for the air bag Havent checked no. will check that. how do i reset the airbag ecu? is it dissconnect the battery for a few minutes. ________________________________________ "if in doubt flat out"Breaking 206 gti |
pug-gti-6
I have changed the bulb on the instrument panel. the airbag light is now on. anyone got any ideas how i can make sure the airbags work and to get the light to stay off.________________________________________ "if in doubt flat out"Breaking 206 gti |
gti6neil
Regular Location: under the bonnet Registered: 07 Jun 2010 Posts: 115 Status: Offline |
pug-gti-6 wrote: I have changed the bulb on the instrument panel. the airbag light is now on. anyone got any ideas how i can make sure the airbags work and to get the light to stay off. only way to test an air bag is to crash the car i should just have confidence that they will work,the light can be put out by the use off a resistor in place off the drivers airbag think it has to be about 2.4 to 2.7 ohms to trick the ecu into thinking that the airbag is still in the circuit when it first turns on. then clear the fault codes in the ecu by pluging it into a diagnostic tool. ________________________________________ yeah the zx td is back on the road front mounted intercooler fitted fuel pump tweaks now required + turbo adjustment |
pug-gti-6
i removed the steering wheel and theres a wire thats been cut. do i solder the resistor onto that?________________________________________ "if in doubt flat out"Breaking 206 gti |
