Author Subject: Car wont turn over ... Please help ...
martin
hey folks ..
just after a bit of advice went out to start my car there ... stuck the key in the ignition 'one' turn to get the power radio comes on etc .. turn again to start the engine and nothing .. car wont even 'turn over' .. any ideas? (the water warning light stayed on so checked the water and theres water in the radator etc)
The car hasnt moved in a couple of days although I did go out and turn it over on monday night started first time.
Theres defo power in the battery lights etc. Just nothing happening when I turn the engine.
Any help or advice is greatly welcomed.
Thanks Martin
Posted 9th Dec 2010 at 23:05
fozzy_255
battery cant cope with the cold weather mines having this problem wait for it to warm up and should start. this happens to mine at the moment.
The battery is far too small so going to get a bigger better one to replace it
Posted 9th Dec 2010 at 23:10
martin
Thanks mate .. appreciate the advice I'll pop out the now and give that a try ...
Posted 9th Dec 2010 at 23:29
martin
Still no joy with that one mate .. gave it a good 15 minutes to see if it heated up but still nothing when I tried to turn the engine ...
Any other ideas - could get my brother in law along for a jump start ..
Posted 9th Dec 2010 at 23:56
aaron6
Run a volt meter across the battery. If its dropped to around 10volts it won't start but lights will still work. Happened on mine last week. A new bosh 530a battery and its good as gold.Smile
Posted 10th Dec 2010 at 00:06
daver6
Does your clock and odometer light up? Or remain unlit or off?
Wishbone Polybushes available
Posted 10th Dec 2010 at 00:07
check the terminals, as well as the earth cables and live cables.
Posted 10th Dec 2010 at 00:09
martin
I dont have a volt meter unfortunately maybe have to think about a new battery I think the battery was replaced only back in June though (got a GTI6 conversion done)
Posted 10th Dec 2010 at 00:32
martin
yes mate the clock and odometer light up radio comes on windows go up and down etc ... so think there should be enough power to even get it to turn?
Posted 10th Dec 2010 at 00:35
rallyeash
try jump starting it from another car, or take the battery off and charge it over night if you have a battery charger.
309 3dr K20 Type R
cwspellowe
Do you hear a loud "click" when you try and start it? Could well be that the starter motor's packed in if that's the case Yes
Bye bye Sundance Kid Sad
Posted 10th Dec 2010 at 03:26
ryangti6
Turn the key with the lights on and see if they go dim or not, if they stay bright it shouldnt be the battery.
Also watch for rev counter or other dials flickering when you try to start it, thats another good sign it is flat.
Ryan
Posted 10th Dec 2010 at 03:30
