Author Subject: Heater DT Vs 6
simonjames
The last week i've owned a D-Turbo (bought it cheap to use during the winter) and used back and fore work, every morning as usual i go out and start the car go in have breakfast then head off to work, this week in the DT im getting to work (5-6 mile) before any real heat is coming through whereas with the 6 it hot leaving the drive
Is this normal ? do the DT's take longer to heat up i've cheacked the system i have no leaks and i've bled it all through
MY EBAY ITEMS
07943066306
Posted 9th Dec 2010 at 19:54
blaze wip
Cant speak for DT's per say but most diesels are slow to generate heat.
My (petrol) Laguna is hot by the time i'm off the estate in a morning where as the works Tansit is only just blowing warm as i get to work! LOL
mechanical_repairs wrote:
i feel like giving her a good dry bumming session.
Posted 9th Dec 2010 at 20:05
simonjames
Yeah thats what i thought but by the time i get to work the engine would have been running 40mins and thought it should be hotter after running for that time
Also fuel ecconomy aint that great i dont see im saving anything much over the 6 as the 6 is so torquey low down i drive everywhere 1500rpm in top whereas the DT im having to rev it to move LOL
Dont think this derv will convert me from being a petrol head
MY EBAY ITEMS
07943066306
Posted 9th Dec 2010 at 20:22
blaze wip
Well i drive 15 mile to work and usually have the van running 15-20 mins before i set off, then it's a 20 min journey.
In fairness it's usally warm about half way to work so say.. half an hour?(ish) before i'm getting any 'real' heat.
Cant comment on the power thing, my van is faster than my car! (110ps Transit, 89bhp Laguna! LOL)
Posted 9th Dec 2010 at 20:31
simonjames
Think the new rallye will be the new winter car when i stick an engine in it and i'll flog this on then
MY EBAY ITEMS
07943066306
Posted 9th Dec 2010 at 21:18
honestly3k
Im pretty sure my meridian heater is better than my 6 heater. The fans and air flow also seem stronger. Also seems hotter when on full settings!
Odd...
Posted 9th Dec 2010 at 21:55
Rich E Forum Admin
It will take a bit longer to get heat from a diesel due to the engines producing less heat but it should only be a few minutes more.
Check the themostat and go from there.
Posted 9th Dec 2010 at 22:00
gti6neil
the 1.9 xud is a little slow to warm up in the winter unless you can get on boost quickly.
yeah the zx td is back on the road front mounted intercooler fitted fuel pump tweaks now required + turbo adjustment
Posted 9th Dec 2010 at 22:32
blocked matrix and a stuck open stat as mentioned.
you dont have to rag it to get anywhere, just drive it off boost and tootle along and you'll be fine Razz
Posted 9th Dec 2010 at 22:37
simonjames
But theres no torque there at low speeds so need to drop it a gear to get it going through the rev range
Got a partner home from work tonight (dw8) and that was the same only just warming up as i pulled up so fingers crossed it aint the matrix Smile though the coolant was very dirty when i drained it yesterday
MY EBAY ITEMS
07943066306
Posted 9th Dec 2010 at 22:51
plenty of torque, just no power Razz
Posted 9th Dec 2010 at 22:54
simonjames
Doesnt even feel as though it has the torque tbh after buying a 207 GT 110 HDI i was sort of liking the derv side of things LOL
MY EBAY ITEMS
07943066306
Posted 9th Dec 2010 at 23:25
anth
The dturbo does take longer for the hot air to come through i find.
Although as soon as you come on higher boost the temp soon climbs.
Posted 11th Dec 2010 at 00:23
simonjames
I don't drive it hard enough then LOL
MY EBAY ITEMS
07943066306
Posted 11th Dec 2010 at 01:38
mike306
Diesels do tend to warm up slower, although my zx isn't actually that bad. They don't have much go until ~2.2k due to the relatively big turbo.
Fuel economy isn't helped by the gearbox, a popular mod is a hdi 'box due to it having better ratios.
Not that it really matters when they can run on veggie oil Wink
High boost '6 for weekends
406 2.1 Executive for weekdays
Posted 11th Dec 2010 at 02:06
