Team Diesel
| Author | Subject: Stereo memory problem on phase 3 |
cornish_pug
Regular Location: Marazion Registered: 18 Dec 2009 Posts: 368 Status: Offline |
Hi guys, seem to have a problem with the memory on my phase 3 took the standard headunit out which was a CD player no make labeled on it but the model number is PU-2294A© put my sony headunit in now the memory doesn't work. Used the same wiring block as my phase 2, on my phase 2 I just plugged everything in and it was fine, i've noticed on the phase 3 the wiring block for the steering colum is different, so I can't use the steering colum kit from my phase 2, any help please guys much appreciated ________________________________________ Team Diesel |
fozzy_255
Senior User Location: portsmouth/Folkestone Registered: 30 Dec 2007 Posts: 677 Status: Offline |
I had the same problem on mine, every time turned car on the cd would go back to the beginning. It turned out one of the wires on the loom had come adrift from the plug. Check yours out see if its missing a wire to one of the pins in the plug |
honestly3k
Seasoned Pro Location: Berkhamsted Registered: 06 Apr 2009 Posts: 2,390 Status: Offline |
I have this same problem. Something to do with there not being a permanent live feed when the car is switched off. Not sure but you may have to switch some wires around...red swapped with yellow or something i heard. Not exactly sure...not attempted to sort my problem out yet! ![]() ________________________________________ ''Oh, it does handle like a golf!'' Why drive a Golf....when you can drive a GTi-6? |
cornish_pug
What colour is the memory wire on the phase 3 i've got a thin orange wire but it doesn't meet up with the memory wire from the block which on the sony is blue, they're in opposite slots so don't line up with each other, is this the problem?________________________________________ Team Diesel |
andy306gti
Regular Location: Ilkeston, Derbyshire. Registered: 12 Jun 2008 Posts: 173 Status: Offline |
If I recall right the standard 306 wiring for the permanent and switched lives are reverse of convention. Be warned though I swapped them around on my sony loom and found out that the permanent is only fused at 5 amp so once I cranked it up it blew the fuse. I think the factory headunit draws its current from the switched feed rather than the permanent and only uses the permanent for its memory whereas my sony draws from the permanent and only uses the switched as a trigger. You can move the fuse in the fusebox to make the switched line permanent however my headunit kept draining the battery in this configuration and in the end I amped my rear speakers and just ran it off the 5amp which has been fine ever since.Then again I did this almost 3 years ago and my memory of it is a little hazy. |
kingston509
Newbie Location: newbury Registered: 07 Dec 2010 Posts: 30 Status: Offline |
hi i sufferd same problem and just swapped the yellow and red wire and it solved it |
cornish_pug
great, i'll swap the red and yellow over and see what happens.Thanks for your help guys!!! ________________________________________ Team Diesel |
cooper666
Senior User Location: doncaster Registered: 27 Nov 2009 Posts: 778 Status: Offline |
theres two positions the fuse can go in in the lower fuse panel iirc it changes where the permanant live goesfusebox clicky scroll down till the picture of the lower fuse panel look at position 24 you will see it can be moved and that will swop the live feed over no need to cut/ change wires. did this on mine with a sony head unit no problems so far ________________________________________ clio r27ps3 id:cooperkloe |
cornish_pug
sorted kingston509, swaped the red & yellow over and now it's all as is should be cheers mate ![]() ________________________________________ Team Diesel |
Well shit the bed I never knew that fuse could be moved |
