Author Subject: draining collant?
j1mmy
which pipe should i disconnect to drain the coolant out as mine doesn't have any antifreeze in it an is a full of rusty water i need to to get this sorted today!
With the hours i work an having my son every weekend i'm just not getting the time!
now a very happy an proud GTi6 owner! Big grin
TEAM: Blaze phase 2
TEAM: Off the road for now Sad
Nimrods going up 4 sale will be available in the next week! Pm if interested.
Posted 5th Dec 2010 at 17:50
the one at the bottom LOL
Posted 5th Dec 2010 at 17:57
Snigger.
There are plenty to choose from, I disconnected one of the big ones going into the bottom of the engine last time, made a right mess but emptied the engine in about three seconds Smile
I then made up a header tank from a coke bottle and flushed it all out with a hose.
Oh, and don't forget to undo the bleed screws...
Posted 5th Dec 2010 at 18:37
j1mmy
would that be the one next to the alternator lol Big grin
TEAM: Blaze phase 2
Posted 5th Dec 2010 at 19:27
j1mmy
Snigger.
Awesome but now i'm confused lmao Huh?
I'm new to these an my cav was simple and spacious to work on lol could you give a bit info on this please especially the bleed screws! When u say u made a headertank did u put it on end of the hose u disconnected?
TEAM: Blaze phase 2
Posted 5th Dec 2010 at 21:57
cwspellowe
Look at the radiator, at the bottom will be a pipe that runs from the rad and across the front of the engine block. Bit of fiddling with some mole grips to get the spring clip off and that's it, iirc it's the lowest part of the coolant system so ideal to drain it.
There's three bleed screws. One on the heater matrix pipes that go into the bulkhead, just to the right of the master cylinder. One is on top of the thermostat housing on the engine block. Follow the big pipe from the top right of the rad to the engine and you'll see a brass allen headed bolt sitting on top of the housing. Finally there is a screw on top of the rad where the big pipe joins the top of the rad Thumbs up
As for a header tank, take the rad cap off. Cut the bottom of a coke bottle off and turn the bottle upside down, then wrap insulation tape over the neck of the bottle until it fits snugly into the top of the rad where you took the cap off. Bleeds by gravity so you need to keep the header tank topped up, helps if you park the car facing uphill to keep the water level in the header tank higher than the highest bleed screw, the one on the heater matrix/
Job jobbed.
Bye bye Sundance Kid Sad
Posted 5th Dec 2010 at 22:06
cooper666
what about the radiator drain right hand side lowest part of the radiator.thats what its there forSmile
clio r27
ps3 id:cooperkloe
Posted 5th Dec 2010 at 23:26
j1mmy
nice one cheers mate so do i have to adjust these bleed screws? And the pipe on radiator is the one just by alternator? Unfortunately by sounds of things some one has changed the clip to a jubilee one i had ago @ it earlier with no luck! Sad
TEAM: Blaze phase 2
Posted 5th Dec 2010 at 23:35
j1mmy
Please elaborate mate please please Big grin
TEAM: Blaze phase 2
Posted 5th Dec 2010 at 23:36
cwspellowe
Given the lack of space down there i'd prefer having a jubilee clip!
I always use that pipe because you can blast water back through the rad and back flush it as opposed to just draining it.
Posted 5th Dec 2010 at 23:41
cooper666
rad clicky
only picture i could find its a nissens radiator but the 3 standard 306 rads i have changed all had the rad drain some may look different though.
clio r27
ps3 id:cooperkloe
Posted 5th Dec 2010 at 23:51
Its not there on all aftermarket rads + its easier to whip a pipe off
Smile
Posted 6th Dec 2010 at 00:01
cooper666
dunno the 2 dtubo ones i have changed had them but instead of a buterfly screw they had a plastic bolt.and the one i changed on my 6 had a plastic rounded bolt with a allen head . theres that many versions about though some may have it some may not .ive never known a radiator on any vehicle not to have one though.
**edit** radiator change clicky
seems like some do some dont
clio r27
ps3 id:cooperkloe
Posted 6th Dec 2010 at 00:06
Maybe I just never bothered looking just always pulled the lower pipe off the rad LOL
Posted 6th Dec 2010 at 00:07
j1mmy
ok have had ago at this today just want to make sure i've done this right will be doing again soon to flush and clean it all out properly! The bleed screw on heater matrix pipe's is it the plastic one just behind the heat sheild? Also once drained do you remove the bleed screws completely then refill?
TEAM: Blaze phase 2
Posted 13th Dec 2010 at 04:08
You'll know if you're drained it right, as you'll have a big wet shiny driveway Smile
That's correct, to refill you'll need to make yourself up a header tank so the reservoir is above all the other points in the system, then fill it up with all the bleed screws open (not removed if you have the butterfly type) until the water comes out of each, then close the valves.
I then tend to run the engine for a bit (best done with a cold engine so you don't burn your hands when the coolant instantly heats up) - this'll start the water pump and will displace any air bubbles around the system. Then I go about the bleed screws one by one and bleed them like you would any radiator, until the bubbling stops and you just get a steady stream of water out.
Header tank, if done professionally, looks something like this:
Edit: And the matrix pipe bleed screw is the bit marked in blue here:
Posted 13th Dec 2010 at 12:50
j1mmy
will i need to remove the heat sheild to get to the heater matrix bleed pipe? The one on mine didn't quite look like that.
When i refilled i had a stream of water coming out of the bleed screw on the thermostat housing and out of the bleed screw on top of the radiator by the top hose that goes to the thermostat housing but not out of the other one is that ok?
TEAM: Blaze phase 2
Posted 14th Dec 2010 at 00:54
No you won't have to remove the heat shield, that'll be fine.
Without a header tank only the two you mention will bleed properly, if the matrix one isn't p*ssing water then it's still got air in it, hence needing a header tank to make sure that happens. It's the matrix one that's the highest, so it's important to get that one bled.
Posted 14th Dec 2010 at 02:03
alcon
Theres an FAQ on this. Follow that and you can't really go wrong
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 14th Dec 2010 at 02:22
j1mmy
thanks lads i think i got it now lol Big grin Wink
TEAM: Blaze phase 2
Posted 14th Dec 2010 at 03:57
