Author Subject: Crankshaft/Bottom end Mods
eddy_gti6
Right i have a spare bottom end sitting in my shed and i no there is alot that can be be done with one. I have been doing my research Big grin
Parts supplied from Rich_w
* Billet Steel Flywheels [Light weight] - £200
* Uprated Main & Big-end Bearings - £115
* Uprated Head Gaskets with Head bolts - £120
* Alloy Engine Pulleys (Crankshaft, Guide/Idle & Auto Tensione) - £140
TOTAL = £575
Other parts
* Forged/Wossner pistons and rods - around £1000
Anyway back to my question... is there a different crankshaft you can use? like light weight one or something?
Posted 5th Dec 2010 at 19:11
clen666
if you are getting custom pistons you could get an 88mm crank to increase capacity.
I believe you can use the steel crank from a 1.9 Dturbo.
I think there is an 88mm balanced steel crank in one of the mi engines (mi16?) but could be wrong.
(if anyone has one of these I may be interested!)
Team 'unintentional rat look'
Posted 3rd Dec 2010 at 17:20
is it going boosted?
and if not will you ever be taking it sprinting/hillclimbing/track racing?
Posted 3rd Dec 2010 at 17:23
chris with a pug
you can buy a billet one, there was a link to one posted up a while back but about a grand. There isnt much wrong with the standard one, Rich put over 500 BHP through his.
However not sure how high reving will affect it, all depends on what you want the engine for.
And you could get it all balanced.
Posted 3rd Dec 2010 at 17:24
ryangti6
The diesel crank as said above is steel and a fair bit lighter than a normal XU10 one. iirc when I weighed the two there was something stupid like 4Kg's difference.
I know the MI ran the longer stroke but wasnt aware they are also steel.
I've always fancied trying to do something with S16 rods and pistons and the diesel crank. I measured an S16 and it would appear that they come to 1mm under deck height at TDC so the crank would bring it back flush like the GTI6 motor is standard.
Ive never bothered sitting there and calculating the Cr this would give though and if it were that simple I would think others would be doing it.
Ryan
Posted 4th Dec 2010 at 02:33
eddy_gti6
just i always seem to be having problem after problem so i am wanting to buy everything new so i may aswell go for uprated stuff. alsoo would be looking at cams and maybe TB's later next year. as for use of the engine it will be used on the track quite abit next year as i intend to get to asmeny track days as i can. already have a fully stripped interior, fiberglass bonnet, brembos ect... = Track Slag Devil
Posted 4th Dec 2010 at 05:41
might as well get a 92mm diesel crank and 88mm pistons then Big grin
Posted 4th Dec 2010 at 14:57
eddy_gti6
whats the difference like? will i need block work done for the 88mm pistons? 92mm diesel crank from what? hid, D.turbo, 1.9 deisel
Posted 4th Dec 2010 at 22:30
cooper666
crank clicky Smoke
clio r27
ps3 id:cooperkloe
Posted 4th Dec 2010 at 23:15
2.1 TD crank
it makes for an engine knocking on the door of 200 lbft's and 240 ish bhp with very mild cam upgrades if its done right.
Posted 4th Dec 2010 at 23:34
eddy_gti6
406 2.1 td crank work ok with standard pistons?
that BTCC crank is a bit much for my liking cooper
Posted 5th Dec 2010 at 01:41
you'll need custom length rods but other than that they would run.
Posted 5th Dec 2010 at 01:47
eddy_gti6
hmm may well look into that Thumbs up i will be getting parts listed above from rich_w at some point next year maybe this wear if i can afford any before xmas
Posted 5th Dec 2010 at 02:04
How about buying the engine off shakey?
It was completely rebuilt with gen pug parts by brett black rallye.
Posted 5th Dec 2010 at 02:28
eddy_gti6
prices? i fancy some nice uprated and lightened parts Big grin
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 5th Dec 2010 at 02:39
gti-dan
cooper666 wrote:
Would that be a straight swap? How much lighter do u think it'd be? Can u get lightweight clutches without spending too much?
Posted 5th Dec 2010 at 23:04
clen666
Mei, is that crank used in anything else, like a xantia or something?
Posted 5th Dec 2010 at 23:18
rhyds
I know tjis thread is a few years old but just checking before i bin my dturbo engine, it has a steel crank?
Posted 20th Feb 2014 at 23:05
rallyeash
Have got wossner pistons and pec rods for sale. Happy to split too.
309 3dr K20 Type R
Posted 21st Feb 2014 at 06:51
eddy_gti6
Nothing like bringing a 4 year old thread back to life Laugh my ass off
Are them roads and pistons for a gti6 crank or a diesel crank ash?
Posted 21st Feb 2014 at 07:30
rallyestyle
I didnt check the date in the first post and was like 'wtf, this guy cant stop starting projects' LOL
Just Drive It
Posted 21st Feb 2014 at 16:58
