Author Subject: Avo coilovers and Kad top mounts
pugheaven
Hi im looking at getting the kad top mounts on ebay to use with my Avo's.
What is the thread pattern of the top nut as kad offer these sizes:
M12 x 1.25/1.2/1.75
M14 x 1.5/1.75/2.0
I think the thread is M12 x 1.25 pitch but im not 100% sure can someone confirm this?
Posted 2nd Dec 2010 at 18:20
mabgti
NV motors
IIRC you are correct!
You got some top hats sorted?
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 2nd Dec 2010 at 22:03
pugheaven
Iv looked on rally design and compbreak for the sleeved nuts so that i wont need to have the shock turned down in a lathe so i have a decent amount of thread for the nut, but i havent looked into top hats, didnt realise i would need different ones?
Posted 3rd Dec 2010 at 15:08
Which ones have you found on ebay? When I looked, only KAD ones I found were for a 205 or 309, will these fit the 306?
Posted 3rd Dec 2010 at 15:20
pugheaven
they will once you get a set of metal moons for midlife, weld them in drill new bolt holes and you can use 205/ 309 ones, the moons are £12
Posted 3rd Dec 2010 at 15:28
lotek
im worried im gonna have the same problem Yes
i dont think there will be enough thread to fit my topmounts to coilovers No what can i do apart from stick rod in a lathe?
Posted 3rd Dec 2010 at 15:51
stick it in a CNC machine?
Posted 3rd Dec 2010 at 15:57
mabgti
NV motors
Stick the nut in lathe! Search for my eccentric mount thread!
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 3rd Dec 2010 at 16:04
pugheaven
like i said compbrake sell sleeved nuts that have tread in the sleeved part, the sleeve part allows more thread to bite to, you will only have half or one thread sticking out the top of the nut but the sleeved part allows more thread bite area compared to the standard nut. As they are not pillowed top mounts i should be able to use the original top hats supplied with the coilovers?
Posted 3rd Dec 2010 at 16:38
Thats a bad way to do it as you are relying on the weak locating collar of the nut to do all the retention of the rod on rebound. One thread into the thick part of the nut just is'nt enough. you will need to modify the rods, or find a thinner top mount bearing so you can get more of the nut doing it's job. I had thew same problem mating my Gaz Golds to my Compbrake top mounts. Ended up having the shoulder on the rods turned down by another 10mm.
Posted 5th Dec 2010 at 16:59
mabgti
NV motors
Someone bloody link my thread.. your questions will be answered.. im on the phone so cant at the mo
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 5th Dec 2010 at 23:33
midlife
The tophats will be fine, the KAD mounts come with the tophats, you just need to specify what thread you want as per the op's question.
A couple of mods to the strut tops for the KAD adjustable top mounts
Cool
Team 330™Cool
Team "no front end or engine"
Posted 5th Dec 2010 at 23:44
