Author Subject: High Temp
d_bradfield
Couple of times this has happened now, I've done a search but couldn't find much. When I've been sitting / slowly moving in traffic the engine temp has shot up to almost max (about 110) Fans kick in and the temp creeps back down to normal (90ish) but then a little while later it happened again...
No warning lights or anything on the dash... any thoughts?
Posted 30th Nov 2010 at 02:18
heliosphan
Could be that your fans aren't working on the low speed function which occurs at 97 degrees. At 107 they go into high speed mode, this may be what's happening to yours. Can't remember what exactly controls what speed they run at though. Maybe the relays on fan housing?
Posted 30th Nov 2010 at 02:39
d_bradfield
I'll double check but I think they are working at low speed, i remember hearing them kick in before.
Posted 30th Nov 2010 at 17:15
cosmic spanner
Moral objector
Pull the connector on the brown coolant temp sensor (on the thermostat housing) and check both fans spin up. If one isn't turning then as said, you'll have lost low-speed mode and it's just the one fan kicking in at high temp/high speed.
If that's the case then check the relays (the two green ones that control each fan plus the black changeover relay between them). There's a wiring diagram in the FAQ section.
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 30th Nov 2010 at 18:53
jonnyvandijk
I had the same problem. Turned out to be a dodgy earth in the wiring by the fans.
Black 306 GTi-6 Ninja 175.8BHP SCA Norwich Project
Topaz Blue 205 CTI Happy
Posted 30th Nov 2010 at 21:59
