If you tow start it it works fine but not from the key, just turns over and never catches. Peugeot reckon this is because there are 2 different types of ecu for the 306, a single sensor and dual sensor one, and this is the wrong one.
Can anyone shed any light or tell me a way to get this ecu (dual sensor?) to run on this ecu?
Thanks
jdcorr
There may have been on the Citroen Xsara VTS as I know the Saxo went from single to dual lambda setup (and a more complicated ECU/multiplexed setup as a result).
