DOES ANYONE KNOW WITCH WAY THEY GO??
OR GOT A PIC OF WHAT IT LOOKS LIKE??
| Author | Subject: airbag wires on steering wheel |
sqweeky84
Newbie Location: rugby Registered: 07 Nov 2010 Posts: 7 Status: Offline |
on my 306 its got a aftermarket steering wheel, i had to remove it the other day and ive noticed that the wires for the air bag connecter have broken away!! im going to solder wires back on but i dont know witch way they ment to go,DOES ANYONE KNOW WITCH WAY THEY GO?? OR GOT A PIC OF WHAT IT LOOKS LIKE?? |
I had exactly the same issue when I got excited with mine, general consensus seemed to be that it probably didn't matter, but I ended up doing away with the airbag before I found the actual answer. Annoyingly all the Peugeot online documentation is done in line diagrams, so can't even see on there. If you've got an aftermarket wheel, do you need the airbag connector anyway? ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
sqweeky84
true! don't really need them, but just would prefer them back on, wozen't sure wether it would cause a short or not?? |
At what end have they come off? Did they come off in the same place as mine in that picture?However they've come off you'll have an airbag warning light on as the airbag isn't present. Anything that looks like it might short out it's always worth wrapping in insulation tape do it doesn't. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
sqweeky84
owain wrote: At what end have they come off? Did they come off in the same place as mine in that picture? However they've come off you'll have an airbag warning light on as the airbag isn't present. Anything that looks like it might short out it's always worth wrapping in insulation tape do it doesn't. yes the same place as yours have, seen sum on ebay so may just buy one of there |
russbez
had a stab at looking this last night.Iv also cut my wires when I installed my aftermarket wheel couldn’t get these resistors to do jack shit Have not check passenger seat connection right enough. My wiring stops at the steering column. Could I just put the resistor there instead of having to have said swirly switch wired up with a resistor on it? p.s i have no airbags in my car, this new "law" is shite, although i will manage to get Rallye through Mot before march. My estate 306 in October will have same problem with light not coming on and going off. ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
russbez
managed to sort my airbag lightwas my passenger side used 1.8 ohm resistors owain ; sorry couldnt see where wires went to that switch actully cracked mine trying to remove a black clip trying to take pictures of wires. anyways my resistor is pluged ito a small brown plug as i no longer have airbag it turned out to be the passenger side tensioner wiring that was duff.... put a resistor in there too and airbag lights now behaving its self ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
russbez wrote: owain ; sorry couldnt see where wires went to that switch actully cracked mine trying to remove a black clip trying to take pictures of wires. No worries mate, ditched it and took out the bulb some time ago ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
russbez
or get one from scrappy? pretty sure this is my second one as i destroyed my first one when i put aftermarket wheel ononly use it for putting indicators off ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
