Author Subject: ticking RFS-engine..
tom97gti
hey guys,
I heard this is a common problem with these engines.
My engine is still ticking after overhauling the complete cylinderhead. there were 2 faulty valves in there, we changed them and provided the head of new seals.
Before I bought it, another garage tried to solve the problem 2 months ago by changing the following parts:
- waterpump
- all in- and outlet valves (yeah, and still 2 got bent in one month time)
- cam followers
- distribution belt
- tensionroller
I'm out of solutions, maybe some one else had the similar problem ? I'm sure it's got nothing to do with the pistons or crankshaft or something like that..
it's about a GTi from 97', 62k on the clock.
Posted 25th Nov 2010 at 14:41
cosmic spanner
Moral objector
Yeah, it's common in heads that have been incorrectly repaired after a cambelt snap etc.
The tapping is usually caused by bent valves and/or damaged valve guides, in your case I guess it's the latter. Do a search for "tapper" should tell you what you need to know.
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 25th Nov 2010 at 16:39
As Mike said Yes
If it has been a tapper, been rebuilt and still taps, either valves were bent when putting engine back together, or the valve guides are damaged.
Posted 25th Nov 2010 at 16:45
tom97gti
it's been completely overhauled. the faulty guides and valves were all replaced. so why would it still tap I don't get it ?
I think it would be very stupid of them not to change them..
Posted 25th Nov 2010 at 17:48
Rich E Forum Admin
You have to be very careful when refitting the head and timing the cams as the valves can hit each other resulting in bent valves.
I would imagine that either the guides and/or seats weren't checked properly or a couple of valves were bent slightly when timing the cams.
Posted 25th Nov 2010 at 20:04
tom97gti
it isn't the adjusting and refitting of the parts. our mechanic has over 25 years of experience in the rallye world so that can't be it..
all the guides, seats and seals have been replaced so that also wouldn't be the problem.
Posted 25th Nov 2010 at 22:35
Rich E Forum Admin
Well if he's so good and so experienced then why can't he figure it out?
If you're so sure it's nothing to do with the head then start looking elsewhere. The vacuum pump has been known to cause a tapping noise on occasions.
Or it could be the beginnings of a bottom end failure?
Posted 26th Nov 2010 at 01:30
