Author Subject: bad oil leak wheres it coming from?
a1rak
got a very bad oil leak somewhere near the starter motor under the inlet manifold. Anyone know whats under there as I cant see into that part of the engine. Its well above the oil filter to the right. Will strip it down soon but would like to know what it could be? Engine runs fine apart from the leak.
Posted 19th Nov 2010 at 22:00
Head gasket?Ninja
Or theres a bung in that sort of areawhere you can fit a oil pressure gauge into the blockWink
Its a blanking plug in there on Gti6 as standardSmile
Posted 20th Nov 2010 at 19:56
more often than not its a sensor/sender not just a blanking plug.
Posted 20th Nov 2010 at 21:57
Which sensor/sender?????Unsure
Posted 25th Nov 2010 at 02:03
oil pressure Smile
Posted 25th Nov 2010 at 02:09
oil pressure Smile
In the hole on the far right hand side of block looking from the front?Unsure
Was a blanking plug in my VTS eng,oil pressure is other side of blockWink
Sure its the hole that S16 had sender for oil press gauge fitted in?
Posted 25th Nov 2010 at 02:24
The adapter you can buy off Miles to fit pressure sender for oil gauge when converting 205/309 to Gti6 lump screws in the hole I'm on about Wink
You can see the blanking plug in the top of the adapter in pic,that was screwed into block.
Oil pressure switch is over the other side of block lower down Smile
Wink
Posted 25th Nov 2010 at 02:34
yeah, many gti6's had a sensor in both holes.
Posted 25th Nov 2010 at 02:38
tvrfan007
Anyone know what thread that pressure take off is? I have an aftermarket gauge with sensor and need to make an adaptor.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 25th Nov 2010 at 02:39
Oh right,what was that all about? Crazy
Same thread as oil pressure switch thats in block just above oil filter,if thats any help!LOL
Posted 25th Nov 2010 at 03:35
16 x 1.5 IIRC.
Posted 25th Nov 2010 at 03:38
a1rak
found the leak as someone said it was from the oil pressure sender unit. somehow it had become loose.
Posted 25th Nov 2010 at 23:41
