Author Subject: not a 306!!
mr swampy s16
**BAD SELLER**
well when i got the coupe i promised the mrs i would leave it as standerd as when i picke it up.
well that aint happend.
as i sell bolts, nuts and braided brake lines these are the first bits to get changed.
when i had to take the tb off the other day i measured a few bits up and have replaced the bolts.
im not modifying just replacing rusty bolts dear Big grin
next up is to measure a few more of the more visable ones up before moving on to the less easy to get at!!
aim is to replace all the old bolts in the bay with shiney new ones.
once done ill offer them as sets to the forum users
if i get chance tomorrow ill be checking the brake line lengthes and specs prior to getting a set made up in stainless steel braided .
oh and ibe changed the indicators to smoked items, look good and seamless apposed to the big orange things
right then had a bit of spare time today so have fitted up a few more bolts and measured aload more which il be getting in the week.
front cam cover, will replace all of them, havent had the cover off but i assume there is another four on the inner edge and the same on the rear covers?
all will be done in time
throttle body cover and body!!
all have being replaced
upper engine mount nuts,the bolt will be replaced aswell with a matching one once i get it.
dusk reflection in the paint on roof
think the next step will be a respray of the strutbrace and the engine cover bit
either in polaris blue or the same grey as the mirror backs
all the bolts under the front cover have now being replaced
just got to stock up and pluck up the courage to remove the inlet and do the rear ones
reall need to do something with the corroded parts of the engine but am unsure as to what just yet.
ok more work done
have gone from the above
to this
still needs a bit more work, but im unable to get down the shed and use the buffing wheel
i will get a nice shiney engine bay!!
:evil:
Posted 18th Nov 2010 at 17:20
mr swampy s16
**BAD SELLER**
new bonnet badge
proper cf none of that dynoc stuff
boot badge is being treated to the same thing
Posted 7th Jan 2011 at 15:54
berger
Too much like hard work to look up the correct order with which to undo/tighten the cam cover bolts, remove and refit new ones and torque them all up correctly!
When it comes to engines, if it doesn't leak oil, leave it well alone imo!
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 7th Jan 2011 at 16:30
lotek
Subtle touch with the bolts but very effective Thumbs up
Posted 7th Jan 2011 at 19:13
sarthe82
Those shiney bolts look great next to the corrosion and gaffer tape. Mellow
Steve Big grin
Posted 7th Jan 2011 at 23:29
mr swampy s16
**BAD SELLER**
What tape that is on the car when it leaves the factory?
Posted 8th Jan 2011 at 02:19
Are they stainless allen caps in the strut tops?
What grade are they?
Posted 8th Jan 2011 at 03:07
berger
Zinc coated 12.9 at a guess.
Posted 8th Jan 2011 at 03:41
mr swampy s16
**BAD SELLER**
Nah as said 12.9 grade steel ones.
Due to the brittleness of stainless i wont fit / recomend stainless is used on any suspension item.
Posted 9th Jan 2011 at 19:02
Smile
Thats what I was thinking,never seen 12.9 zinc coated Cool
My hard ware place only has 12.9 in blackRoll eyes
Posted 11th Jan 2011 at 14:23
