Author Subject: TSW Alloy Wheels - Cannot loosen 75mm nut to remove wheels
shredder11
I have TSW Blade 15x7 ET 35 Alloy Wheels which have a centre plate, held in position by a 75mm hex nut. Unfortunately my rear wheels cannot be removed as each 75mm nut has seized on tightly; I do have a special TSW hand spanner, but that is too flimsy and short to get any leverage etc. I have looked online at getting a 75mm socket and a long bar but they all use 1" drivers and the prices made my eyes water! £60 for the socket minimum and £500 for the long bar! Shock
So the question is, can anyone suggest what sort of places I can go to get the nuts loose, so I can grease them to prevent it happening again? I went to a local truck and lorry service & mot place the other day, but the largest socket they had was about 65mm. I think they even had a double decker bus and the centre nuts were smaller than mine too. Surely there must be places with air tools and a range of sockets? Perhaps a TSW specialist place?
I've had brake disc and pad problems recently too, and I could only reach through the alloy spokes with wet and dry paper, to scrub my discs but to do it properly I need the wheels off. The pads are rubbing against the discs while driving, so the pad material is all over the disc surface and grooves and dimples.
If anyone can help with suggestions or even offer to use their own socket and bar, I would be very grateful!
shredder11 has attached the following image:
Posted 17th Nov 2010 at 17:46
tvrfan007
Is that not a plastic nut? Nobody in their right mind would fit a 75mm nut surely. Shock
Angle grinder ftw!
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 17th Nov 2010 at 18:18
simonjames
Soak it daily with wd40 it will work in then hammer and chisel to knock the nut araound, i had the same deal on a set i had the alloy corrods with the nut on
MY EBAY ITEMS
07943066306
Posted 17th Nov 2010 at 19:13
Could you get a g-clamp on it? That's what I'd be trying.
Posted 17th Nov 2010 at 19:41
dragoon
the type is Avus R btw Wink
these bolts are alloy, but I always got mine loose with the tsw-spanner.
you can always try heating it?
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
shredder11
Ahh right I will persist with a lot more WD40 then, but I guess not too much as most will just run down away from the nut otherwise.
Actually my fishman suggested a trip to the local scrapyards as they have to deal with whatever stuff comes in.
Posted 17th Nov 2010 at 19:43
shredder11
Yeah Avus R and Blade tend to come up in Google image results. I've seen people selling them and calling them Blades too. They were on the car when I bought it back in 2005.
Posted 17th Nov 2010 at 19:44
simonjames
blades had the spokes to edge of teh rim
MY EBAY ITEMS
07943066306
Posted 17th Nov 2010 at 19:56
shredder11
Oh right, thanks for the info on the Blades; so I definately have Avus R then.
Here is the 75mm nut which seems to be metal judging by the weight and feel. It screws on clockwise and the litte white arrow on the back of the nut shows this. I took this from one of the front wheels as they are still ok, plus I sprayed on some White Lithium Grease to both wheels a few minutes ago; bloody cold outside though, especially with the wind!
Posted 17th Nov 2010 at 20:39
rallyeash
either way, dont fit them back on! there horrible
309 3dr K20 Type R
Posted 17th Nov 2010 at 21:21
dragoon
they're not THAT bad tbh:
(for sale btw Whistle )
Team Wheelwhore
Posted 17th Nov 2010 at 21:59
rallyeash
Yes they are... proper 1990's
309 3dr K20 Type R
Posted 17th Nov 2010 at 22:07
rich-6
Water pump pliers?
Cool
RIP Pete Sims
Posted 18th Nov 2010 at 04:50
shredder11
UPDATE: The nuts are off! After the first garage's feeble attempts with a crappy tool, this evening I went to my local tiny scrapyard and although they did not have a suitable socket, they had a much sturdier adjustable wrench with long, straight, narrow width jaws and a wide capacity of course. I forgot to ask him where he got them from as I was so pleased and relieved to get those nuts off (made me really depressed and down and worried). Anyway I will bob back and ask him when I get chance.
I've since sprayed on loads of Copper Grease on both the alloy hub threads and the 75mm centre nut threads. Out of the four nuts, there is one that does not smoothly screw fully on, so if I leave it slightly loose the wheel nut cover rattles, although I do not know what this will be like until I drive the car.
Thanks for all the help and suggestions, I very much appreciate it and especially as I am a new member here and not really contributed much.
Thank you all. Thumbs up
Posted 19th Nov 2010 at 03:30
