Author Subject: Spark plug fail
wavey6
I found this today, I changed the plugs and it drives spot on I even gave it good spanking along the A4 just for good measure(chiswick and back).
Will the obvious missing part fall straight through into the internals, if so would I notice something wrong immediately.
wavey6 has attached the following image:
J'aime mon peugeot sexy 6
Posted 17th Nov 2010 at 01:08
brownboy
pic isn't working mate
Posted 17th Nov 2010 at 01:04
wavey6
Yes
Posted 17th Nov 2010 at 01:07
jcphat
If the engine is going as well as you'd like and not tapping you may well have had a lucky escape and it's gone out with the exhaust.
New Forum same high quality intellectual debate!
Team Zimmer™
Posted 17th Nov 2010 at 01:11
wavey6
Engine sounds sweet as per usual, would I notice something wrong instantly Whistle Ninja
Posted 17th Nov 2010 at 01:25
wavey6
Bumpy anyone know how long max before I could see, feel, or hear a problem.
Posted 17th Nov 2010 at 04:45
CUJ
Shock Jesus! If that goes through the engine without any issues I will be amazed! GL!
340 horses
Posted 17th Nov 2010 at 04:51
Depends to be honest you may never have a problem or it could have stuck itself to the piston and may or may not move and cause damage at a later date. Had an evo at work that had a cambelt jump with seemingly no problems. There supposed to be a safe engine but clearly something hit as 6 months later there were bits of valve guide on the top of a piston smacking into a spark plug causing similar damage to what yours did.
You have 2 choices really, either forget about it as she's running sweet and hope nothing happens down the line, or take the head off just for a looky and piece of mind.
Pete.
