Author Subject: Blower stopped
mikebee
As above, the blower has stopped on my 6. Other than the fuse (which I've checked) what should I look for?
Posted 17th Nov 2010 at 00:42
brownboy
could be the relay
Posted 17th Nov 2010 at 00:46
mikebee
Would this also affect the a/c? Noticed that isn't working either.
Posted 17th Nov 2010 at 01:11
taken
Yes mikebee, When I bought my 306 the blower wouldn't work, or the A/C. It took me ages to eventually find that one of the GREEN relays in the fusebox was burnt out..!
Team... I drive a diesel Razz
Posted 17th Nov 2010 at 01:52
mikebee
Will check this. It has been intermittent and I did check the relays the other week and were ok, but it could have burnt out.
Thanks guys.
Posted 17th Nov 2010 at 02:01
GTI-6
did you find out what it was? I have the same issue. Blower motor works fine when i hard wire it Sad
Love thy 6
Posted 1st Aug 2012 at 23:06
green relay under dash, all my 306's have had problems with the relay overheating or melting to the fuse board
Posted 1st Aug 2012 at 23:12
aaron6
Mine had this, I changed the motor last week. Been fine since. Mine had other issues to though such as just the fan being intermittent.
Posted 2nd Aug 2012 at 10:08
russbez
another vote for one of the green relays in next to fuse area in the car Yes
My Rallye project thread
Posted 2nd Aug 2012 at 10:37
daver6
Does it work on the fastest setting? (#4)
If so, its the heater blower resistor that has gone
Wishbone Polybushes available
Posted 3rd Aug 2012 at 17:58
GTI-6
My A/C and recirculating fan work. The heater was intermittent. Thought the motor was shot, so I took it to pieces, cleaned the brushes etc.
Result: the motor works when hard wired. doesn't work at all when wired in to the car. Ordered a new blower as I suspect it's the control unit inside the blower itself (sealed board with 3 I.Cs)
there are 3 wires to the unit, 12v +, GROUND and control, this varies between 1 and 5 volts. 5 when the blower is set to low or off and 1 when on full blast, in this correct? I assumed so.
Also, the blower runs constantly, even when set to off. it bugs the crap out of me. From other threads on here, it appears that is normal?
p.s the air con drainage pipe is the weakest piece of crap ive ever seen.
Love thy 6
Posted 8th Aug 2012 at 02:25
aaron6
Mine used to do that, then it just stopped. I changed the motor, jobs a gooden. Smile
Posted 8th Aug 2012 at 06:16
GTI-6
Yeah, I reckon it's gotta be that internal control unit.
I'll stick a photo and diagnosis of it up here when i've sorted it as there seems to be a few threads with similar symptoms, but not solution ( i hate that sorta stuff!)
Love thy 6
Posted 8th Aug 2012 at 06:39
GTI-6
SOLVED!
There is a control unit inside the the blower casing itself.
It has a cast alloy case and is held in by three torx screws. The control unit is sealed under black silicone. I got it all out and an IC had blown.
Replaced whole blower unit as control unit/module cant be found by itself.
I think, basically, if you get 12v+ on the red, GND on the black and varying 0-4V (IIRC), between gnd and control wire, and the motor is intermittent/doesnt work, this is likely the issue. PM if anyone wants photos. cheers.
Love thy 6
Posted 21st Aug 2012 at 06:02
aaron6
Put photos up on here mate. It's a common issue and would be nice to have a finished thread. Good work by the way. Wink
Posted 21st Aug 2012 at 07:38
