I'm hoping someone can help with this. I have a 2000 306 1.8 XS (XU7JP4 with aluminium throttle housing). On cold starts,it'll fire then die unless I hold revs. It'll fluctuate on revs and splutter a few times then pick up.After that, it seems fine. I initially cleaned the ICV and reset the ECU and it worked fine for a couple of days then starts acting up again. I've put a new ICV in which caused erratic idle (1500, sometimes jumped to 2500). Adjusted the screw on the throttle housing which slowed it down to normal, but the problem still exists. I'm starting to think that it might be ECU (Read about the ignition pack issue) Any suggestions?
pug junkie
