| Author | Subject: Flat spot around 3-4k |
sloppy
Senior User Location: Yorkshire Registered: 07 Aug 2005 Posts: 677 Status: Offline |
Running at the mo seems to have a flat spot from about 3 maybe 3.5k to abot 4 to 4.5k then its alive again, stopped and tried unplugging the lambda seemed to make no difference, so any one else had this and was it lamba related, any other ideas. |
On WOT or part throttle? Lambda makes no odds on WOT.Coolant temp sensor Throttle Postition Sensor Cam timing ________________________________________ Nothing to see here |
monty-69
Senior User Location: Colne Registered: 02 Jul 2006 Posts: 792 Status: Offline |
maybe check the cat is in one piece? They are gutless below 4000rpm. |
monty-69 wrote: maybe check the cat is in one piece? They are gutless below 4000rpm. Depends on the cam timing ![]() ________________________________________ Nothing to see here |
monty-69
Ive driven three, all with standard cam timing, one standard, and two with breathing mods. All wouldnt pull skin off a rice puddin in low revs. |
sloppy
and wide open throttle, just seems a bit flat, is the cam timing hard to adjust or do you need new pulleys, or just adjust them on the movement they have? I just removed the cat as i thought this would not be helping. could be just how they are its about 3 years since i last drove a git6. i think about coolant temp, i will swap this and see as i have a spare. |
bo***cks are they gutless, same was often said of the MI16's, its just that they go mental above 4k.timing is easy to check, firstly you need to make 100% sure that the bottom pulley has not slipped, the keyway is meant to be 70 degrees from the locking pin hole, you cna move them a fair amount as standard. one thing to bear in mind, that IIRC you have a restrictive exhaust manifold fitted, this may well cause the engine to have different characteristics to the original engine+manifold combo. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
sloppy
Yea thats true, i think it is prob ok but im used to a v6 and a 2.0 turbo so it feels a little slower. I will check timing though. However unforunately it looks like the head gasket is going so i will have a bash at adjusting the inlet timing then. welshpug! wrote: bo***cks are they gutless, same was often said of the MI16's, its just that they go mental above 4k. timing is easy to check, firstly you need to make 100% sure that the bottom pulley has not slipped, the keyway is meant to be 70 degrees from the locking pin hole, you cna move them a fair amount as standard. one thing to bear in mind, that IIRC you have a restrictive exhaust manifold fitted, this may well cause the engine to have different characteristics to the original engine+manifold combo. |
