Author Subject: Rear brake imbalance on MOT
simauto
Hello everyone,
I'm new to the world of 306's, i've bought my wife a 2000 HDI medderian and it was up for MOT and has failed on a 50% imbalance on the rear right hand side.
I've removed the callipers, cleaned a greased the pistons and went for a retest last night and it failed again on the same thing. its was 48% this time.
hand brake is passing ok its just the foot brake.
any info or advice would be great
Thanks
Derek
Posted 12th Nov 2010 at 18:38
lotek
Bias Valve seized? kinked or creased brake line to one of your calipers restricting flow?
Posted 12th Nov 2010 at 18:47
simauto
Unsure mate, i've read about this bias valve, i'm to take a look for it in a mo.
Posted 12th Nov 2010 at 18:51
footah212
Agree with lotek.
Bias valve or damaged lines
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 12th Nov 2010 at 18:57
lotek
grab hold of it and move it , should spring back on own accord if not then vigorously wiggle back and forth like FOOK, spraying loads of WD40 or whatever on to it.
May have air in brake line aswell, give them a bleed Yes
Posted 12th Nov 2010 at 18:54
simauto
thanks for the tips lads.
very helpful forum!
try bleeding the brakes, a seized load compensator will affect both rear brakes.
try swapping the discs and pads side to side.
Posted 12th Nov 2010 at 18:59
simauto
the brake pads and discs where fitted with new ones bfore the mot
Posted 12th Nov 2010 at 19:41
lotek
Bleed the brakes, then free off the bias valve.
all will be fine after that..
Posted 12th Nov 2010 at 19:46
simauto
Right lads, went for a route round below the car for the bias valve and couldn't find it.
but i did find this at the right rear.
excuse the more iphone pic
Could this be the problem?
seems to connect the 2 sliding pins for the rear caliper.
Posted 12th Nov 2010 at 21:22
footah212
That bracket should be all one piece, thats for sure.
Not sure it will 100% be the cause of the problem but it ain't right. You should be able to get one from a scrappy easy.
the bias valve is on the RH side just forward of where the photo is taken.
It has spring attached to it.
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 12th Nov 2010 at 21:57
midlife
This is what you should be looking forWink
Cool
Team 330™Cool
Team "no front end or engine"
Posted 12th Nov 2010 at 22:17
simauto
Thanks mate, pics speak loader than words
Posted 12th Nov 2010 at 22:21
that wont cause any issues bar a fail of an UK MOT LOL
being a 2000 car, it may not have a load compensator as it could have EBD.
Posted 12th Nov 2010 at 22:30
simauto
does anyone know what the bit of metal that is broke does?
Posted 12th Nov 2010 at 22:35
not much LOL
its a lock plate to stop the bolts from coming loose.
Posted 12th Nov 2010 at 22:41
simauto
LOL LOL back to the drawing board then
Posted 12th Nov 2010 at 22:45
tabbbster
Mine Nearly failed the last MOT on this and it was the sliders in the rear calipers. The lower one on both sides was seized. I knocked them out cleaned them up with fine sand paper. Greased them back up popped it all back together and the inbalance was gone. Smile
My Rallye was built on thursday 7th January 1999 according to the cosmic code generator.
My Cyclone refurb
Posted 13th Nov 2010 at 04:12
I cant see how this is a faliure... you can only fail a car on front imbalance, rear is not measured... you could have a stupidly low amount of braking force on one side and if the other 3 all lock it is still a pass providing over 50% of wheels lock... Total brake efficiency must be more than 50 % for service brakes and 15% for hand brake. You can however fail a car for little to no brake effort if you so choose. I would take the caliper off, free up the piston, bleed it out and re fit. problem sorted. As welshpug said bias valve would effect both rears.
Posted 13th Nov 2010 at 06:26
306weasel
Correct Yes
Car#1 306 HDi Meridian 5door, 133Bhp, 225lb.ft Ecosse R/R 20/3/05
Car#2 306 1.4 3door track car with Gti6 power. 167Bhp, 134lb.ft Ecosse R/R 21/10/07
Car#3 Grand Scenic 1.9DCi (Expanding!) family mover.
Posted 14th Nov 2010 at 00:52
