Author Subject: rallye blowing cold
rallye dave
any ideas gents my rallye has decided to blow cold air when on highest hot setting when on idol its freezing but when driving it improves slightly and gets a little warmer but not much?? recently done head gasket and was fine for few months ive got no water in passenger footwell, and when blowers are on i can smell a slight wiff of coolantany ideas please
Posted 10th Nov 2010 at 22:51
smegal
Get ready to start to see water in the footwells.
I hate to break it to you but that is classic matrix about to go symptoms.
Ex SC-6
Now in a Megane R26
Posted 10th Nov 2010 at 22:56
AIr block as well and hope the thermostat was changed when the head gasket was sorted
Try bleeding the system first Wink
Posted 10th Nov 2010 at 23:07
vernam616
I agree, could be matrix
Was the system bled properly after its refill? try bleeding it from all points whilst warm, start with rad screw, then thermostat then heater matrix pipes
I did my own matrix a few months back, it sounds and looks quite daunting, but i had a friend help me out and it makes it go a lot smoother, id of had it done in 3 hrs if it hadnt been for snapping the matrix pipes :grr
Good luck
Audi S3 Black Edition
Posted 10th Nov 2010 at 23:09
rallye dave
had everythin genuine from pug when gasket done thermostats x 2 n that didnt solve problem bleed up and re bleed but no change i was surprised to not see a wet footwell yet tho best get the tools out!! ps guys there is 2 types of matrix which one do i need as rallye n 6s are different i think?
Posted 10th Nov 2010 at 23:16
vernam616
You need Valeo mate, well thats presuming your Rallye doesnt have the air con option, then it will be the BEHR unit
Posted 10th Nov 2010 at 23:26
tvrfan007
Off topic but where in Peterborough are you fella?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 11th Nov 2010 at 13:50
dead_poetic
is your engine running hot? if your over heating at idle then i'd say your thermostat is shot.
if thats ok...then like the others say, matrix Sad
  • Alexisonfire - Happiness By The Kilowatt
  • 36 Crazyfists - Northern November
  • [bullet]Poison The Well - Lazzaro
    Posted 11th Nov 2010 at 20:14
    :: blade ::
    mines like that, but mine doesnt blow cold anymore Sad
    Black Ph1 XSi-6
    161.8BHP (Getting Better!!!!)
    Posted 11th Nov 2010 at 23:02
