my qustion is can i go bigger the 288mm?
| Author | Subject: brembo 406 on 6 |
nadium
Regular Location: denmark Registered: 18 Jan 2007 Posts: 241 Status: Offline |
hello lads did the search, but the biggest discs i can use is xantia v6 288mm ? i dont need the cyclones ive got 17 " msw designe by oz.my qustion is can i go bigger the 288mm? |
not without a bracket to space the caliper further out radially.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
chrisd306
Seasoned Pro Location: Perth Scotland Registered: 26 Nov 2005 Posts: 10,061 Status: Offline |
Best speaking to Ash as he does a kit, but its with diffrent brembos from a renault meganne im sure. do a search________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
eddy_gti6
yes you do need renault RS calipers to fit adapters as you cant get them for the 406 brembos, think the biggest you can go is 330mm discs________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
midlife
Seasoned Pro Location: Colne, Lancashire Registered: 13 Mar 2006 Posts: 7,544 Status: Offline |
I've got 406 V6 Brembo's & 330mm discs using adaptor brackets & alloy bells from Ash![]() ![]() ________________________________________ Get used to seeing the yellow one !!!![]() ![]() ![]() ![]() ![]() Team 330™ ![]() Team "no front end or engine" Team "LIMITED EDITION" I live for the 306 sticker ![]() Team 0-60 in 6.44 & standing qtr in 14.808 @ 94.55mph all with std engine ![]() 203bhp Corolla T-Sport daily driver stealthier than Kwai Chang Caine |
lotek
Seasoned Pro Location: Berkshire Registered: 04 Dec 2007 Posts: 6,107 Status: Offline |
im giving thought to retrofitting the setup from the 308GT going from what adam said! |
they will weigh half a bloody ton Rick, I think its a two pot sliding caliper, but I can't see from the pictures, they use a 340 x 30 mm disc ![]() they have bigger rear discs than a 6 has at the front at 290x12 ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
lotek
Okay , Maybie il have to rethink it |
It was insane though...________________________________________ Nothing to see here |
they do also run 225 40 tyres and far more modern ABS than a 306, so not surprising they can apply that much braking force ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
lotek
adam b wrote: It was insane though... Better than the upgrade kits available at the moment? |
lotek
welshpug! wrote: they do also run 225 40 tyres and far more modern ABS than a 306, so not surprising they can apply that much braking force ![]() Damn you keep p*ssing on my ideas I suppoese even finding a 308GT being broken for parts will be hard enough ![]() Edit* also how on earth will i manage to retro fit the rear ? and get wheels on ![]() bloody torsion bars |
nadium
but i will only use my 406 brembos without any bells or bracket. is it only the xantia v6 288mm i can use? what about the 305mm from a 406 ? |
lotek
![]() caliper mounting points wont allow the 305mm disc to fit |
nadium
Lotek is th only chance ive got to go bigger is that v6 brembo and xantia 288mm dicsc to fit directly on my 6 <? |
mr swampy s16
**BAD SELLER** Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
nadium wrote: Lotek is th only chance ive got to go bigger is that v6 brembo and xantia 288mm dicsc to fit directly on my 6 <? yes thats the cheapest option that is with out going down the route of a set of bells and rotors from ash |
lotek
![]() that is the biggest that will directly Fit |
