Author Subject: which discs and pads do i get?
slywhite
hi all, just wanting some advice on which discs and pads i should go for now, i have grooved discs front and rear at the moment which i got off of ebay with omp fast road pads, i dont do a lot of hard/fast braking. any help would be great, regards simon.
Posted 7th Nov 2010 at 16:23
midlife
Wow, this question has been asked sooooo many times.
Grooved STD size discs serve no purpose other than looks & reducing the pad contact area thus reducing stopping power.
You say you don't do much heavy braking?
Use STD discs & pads then.
If you like a blast down the lanes now & again or the occasional track day, use STD discs & Ferodo DS2500 pads.
Cool
Team 330™Cool
Team "no front end or engine"
Posted 7th Nov 2010 at 16:36
slywhite
thanks, will give them a try and see how things go.
Posted 7th Nov 2010 at 16:46
Are you experiencing fade or problems with the setup you have? If not, don't change it.
kit
Purely standard is the way forward for every day use with the occasional blast. They are more than enough.
If you do the odd track day then standard discs with either Mintex 1144/1155's or Ferrodo DS2500 pads accompanied with braided brake lines will give you a very good set up.
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 8th Nov 2010 at 01:27
lotek
kit wrote:
Ferrodo DS2500 pads will give you a very good set up.
Shut up
Posted 9th Nov 2010 at 18:56
daver6
I've just got std brembo discs from GSF and some Green Stuff pads to try
Wishbone Polybushes available
Posted 10th Nov 2010 at 13:24
