Author Subject: unlocking ecu?
jeff6
I'm tyring to unlock my ECU , i've searched on here and found You then need to cut pins 27 and 48 on the 55 pin connector inside the ECU.
How do you know which is pin 27/48 as on my ecu the pins are not numbered ? , cheers
Posted 7th Nov 2010 at 04:51
rich_w
The pins are numbered at either end of the connector Yes
There's more to it than just cutting the pins though - you need to clear the immobiliser code from the ECU's processor first, which a specialist will need to do.
I can do it if required.
Smile
Contact Details:
07732 822546
Posted 7th Nov 2010 at 04:54
jeff6
Smile
thanks for reply , so would i still need to send it to you even if i removed it of the car by un plugging ecu with car running? , cheers
Posted 7th Nov 2010 at 16:00
rich_w
No, in that case it should already be unlocked Smile
Contact Details:
07732 822546
Posted 7th Nov 2010 at 16:29
