Author Subject: Battery cold air feed?
hobbs600
I dont really know alot about cars yet, but gotta start somewhere! Anyway I want to make some room for an air filter up top and was just wondering what the deal is with the duct which appears to feed the battery housing, would anyone suggest I remove this and re locate the battery into the back of the car? I just dont like the thought of sucking up water by having a cone filter too low!
If you can't run with the big dogs, don't p*ss up the tall trees!
Posted 5th Nov 2010 at 19:23
lotek
the feed clears gasses from battery tray Yes
if you put battery in boot then you dont need this feed.
id be tempted to stick to the standard intake tho, if you put filter where battery is you will get nothing but hot air sucked in Yes
Posted 5th Nov 2010 at 19:29
mr swampy s16
**BAD SELLER**
I removed the feed to make a bit more room
never had any problems in the 5years i ran it like that
Posted 5th Nov 2010 at 19:45
hobbs600
Fair enough, I was thinking about removing the main beam headlight from the quads so the filter would have direct cold air and sticking a bit of ally plate next to it to prevent hot air off the rad?
Posted 5th Nov 2010 at 19:49
if you put the battery anywhere, you need to vent it somehow
if you move the battery inside the car, you need to put a vent from the outlet on the battery to the outside or you are inhaling charge gasses
Posted 5th Nov 2010 at 19:54
hobbs600
That doesnt sound great! Ill figure something out. I quite like the idea of having it in the car. :s
Posted 5th Nov 2010 at 20:26
rallyeash
race battery FTW
309 3dr K20 Type R
Posted 5th Nov 2010 at 20:31
rallyeash wrote:
race battery FTW
Can you recommend one that will work for a car with occasional use, that won't cost me the earth?
Posted 5th Nov 2010 at 20:35
rallyeash
im using a odossey race battery, cant remember the model but i can look the next time im at the workshop.
although mine is probably abit small for you as it only runs lights and cranks engine. no heaters, radio, electric comforts.
309 3dr K20 Type R
Posted 5th Nov 2010 at 21:16
Rich E Forum Admin
Most car batteries are sealed these days anyway so the issue of ventilation is largely irrelevant now.
Posted 6th Nov 2010 at 20:35
they still have vent feeds on them and should mostly already be in a case so are venting already, thus not a worry really. it was more a case of those who smack the battery in the boot without thinking about it [i did it first time round!]
Posted 6th Nov 2010 at 22:40
