Author Subject: Split flexi pipe?
cwspellowe
Urgh one thing after another..
Anyway, was driving around yesterday and noticed while sat in traffic the brake pedal slowly go flat to the floor. Happened all of a sudden, initial brake pressure is there but after a second or two the pressure releases.
Likely suspect before I go stripping the car down? Thinking it's a flexi pipe has a pin hole and brake fluid is p*ssing out, i don't think the solid pipes would let go in such a way.. would they?
Also if it IS a flexi pipe issue, what size do I need and what fittings so i can pick some up from a 'factor this afternoon?
Bye bye Sundance Kid Sad
Posted 4th Nov 2010 at 17:39
oecken
ive come to the conclusion that the shed of wonders is cursed.. Dunno
Posted 4th Nov 2010 at 17:54
cwspellowe
Quite possibly, was on my way to B&Q to pick up angle grinder discs to make a start on the itb's and this happened Laugh my ass off
mr swampy s16
**BAD SELLER**
the fittings are 10 x 1,
if you mean for the metal pipes you will need a flare tool aswell
i can have a pair of braided lines with you for the weekend for not much more than the rubber ones cost.
Posted 4th Nov 2010 at 18:30
cwspellowe
That's a nice thought swampy. Just a shame it turns out it's the copper line that's popped, must have been corroded or something...
Posted 4th Nov 2010 at 20:05
cress87
Hardly a shame; A copper brake line won't cost much.
Posted 4th Nov 2010 at 23:19
if its original, they're actually steel Smile
Posted 4th Nov 2010 at 23:25
cwspellowe
Hmm when the black stuff wore off the pipes they looked copper coloured to me..?
Regardless of that, the biggest c*nt is going to be trying to bleed the brakes seen as the rear callipers have no bleed nipples Doh
Posted 5th Nov 2010 at 04:06
