Author Subject: Grindig noise after ball joint changed
ballardpaul
Well then another silly noise that has me confused.
This week I changed the nearside ball joint but when I pushed the hub to the side to undo a bolt holding the ball joint on I must have pushed it too far and gearbox oil leaked out from the driveshaft seal. I filled the box back up correctly (not sure if this affected anything but thought I'd add it in)
Now when I come off the accelerator there's a horrible grinding noise from what sounds like the offside??? It stops when you put the clutch down. Any ideas people as I haven't got a clue...
I'm pretty sure I did the ball joint right as I've done one before.
Thanks in advance
Nissan 350Z (300 BHP)
Posted 4th Nov 2010 at 05:08
mabgti
NV motors
sounds like the release bearing, but dunno how you got that just by dropping gb oil!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 4th Nov 2010 at 17:08
ballardpaul
Release bearing for what?
Posted 4th Nov 2010 at 17:47
berger
The clutch...
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 4th Nov 2010 at 21:47
dalton88
Check the driveshaft is in as far as it will go
Posted 4th Nov 2010 at 22:28
wrong balljoint possibly.
Posted 4th Nov 2010 at 23:09
ballardpaul
Haha thanks so much everyone. It was something so basic. I bought a new air feed and fitted It the same day and basically it was that vibrating off on the engine when in gear and moving. Should of checked that before posting on here, but I panicked as it was a horrible noise.
Posted 5th Nov 2010 at 00:09
