Author Subject: Just lowered the 6 :)
mattgti6phase2
Just a short message to let u all know if your looking for a decent coil over kit then ap do one for just over £300 I fitted mine myself and dropped it 60mm on the rear roughly and matched the front accordingly. It looks great and handles like it's on rails. I also went for a 45 profile all round with ze912s can't fault it yet. Lovely Smile
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 3rd Nov 2010 at 13:20
oecken
45 profile No now you dont need to use your speedo (as its pointless LOL) amongst other things....
Posted 3rd Nov 2010 at 13:52
mattgti6phase2
Well with a 55 profile your speedo is still 10% out my speedo with the 45 profile is accurate to within 1mph via constant speed via satelite. What else is pointless??
5 x a 306 owner!
Posted 3rd Nov 2010 at 14:12
bennn
50 profile is the one to go for if its lowered, i had 45 profile cyclone for a bit (because they came off my 106, while mine were being refurbed) and it looked awfull!
Cherry Red 306 HDI
Posted 3rd Nov 2010 at 14:14
oecken
mine didnt look to bad when i got the car, was on 45 profile and VERY low (jimmyrallye for you) but speedo on motorways was litterally making me LOL and after it being that low for so long rearbeam had completly gone, camber on both sides and siezed, so a few hundred pounds with Carl later and new rearbeam, not a spine breaking lowness and handling was back.
im sure there be someone along soon to say "you dont know what ""handles like its on rails"" means until you have it set up correctly" Razz
Posted 3rd Nov 2010 at 14:17
berger
195/45/15?
If it was under-reading by 10% with the correct tyre size on 195/55/15 and then you put 45 profile tyres on and it was correct, then you have found a way to change physics!
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 3rd Nov 2010 at 14:31
mattgti6phase2
Both valid points but each to their own in my opinion. I think it looks awesome and the wheels look great with the 45's handeling is also great it's a fast road set up so not too stiff it doesn't bounce or skip either. I have no camber issues or torsion bar issues at present. I'm pretty sure it's dropped 60mm but can raise it if I ever need to. What are you guys running?
5 x a 306 owner!
Posted 3rd Nov 2010 at 14:39
mattgti6phase2
So the speedo reads out from when your not even moving agreed? Then when travelling at 30 your actually only doing about 27 and when doing 100 your doing about 90 when I put the 45's on it was still out but by slightly more but after tinkering about with it now if I'm doing a 100 for example I'm actually doing 100
5 x a 306 owner!
Posted 3rd Nov 2010 at 14:56
oecken
well i could never get the speedo to actually say 100 when doing 100 on the satnav & snooper.
was running 45 profiles on adjustable avo coilovers at around 75mm, now with new beam new front sus (Springs) only lowered around 50mm on 50 profile, rear solid beam mounts, new droplinks has made a world of difference, its because it was so low for so long i think, the "adjustableness" seized up and wouldnt move as it was left so low LOL but it looked nice at the time Doh
Posted 3rd Nov 2010 at 15:07
cwspellowe
So what you're saying is you played with the needle so it now says you're doing 100mp accurately?
If that's the case you've made it accurate for one speed and one speed only, anything under 100mph will over-read and anything over 100mp will under-read.
Unless you changed the gear size in the VSS your speedo will always be inaccurate.
**EDIT not sure how the electrical speedo's work but you could alter the resistance of the circuit for a more accurate read out i suppose...
Bye bye Sundance Kid Sad
Posted 3rd Nov 2010 at 15:16
mattgti6phase2
Either way my speedo is as accurate if not more than before from 0-142. 75mm is a savage drop I bet she looked sexual! Not surprised the beam couldn't cope after being in that position for so long. I'll try and gets some pics up and you'll have to let me know what you think.
5 x a 306 owner!
Posted 3rd Nov 2010 at 15:23
jon kirby
coilovers lower the back? Blink
Posted 3rd Nov 2010 at 15:30
mattgti6phase2
Well you can adjust the front the rear can't do that but they are easy enough to do
5 x a 306 owner!
Posted 3rd Nov 2010 at 15:40
cwspellowe
You either have strut turret conversion at the back or you don't know what you're talking about Yes
As for the speedo it's just as inaccurate as before, if not worse. Before it was accurate at 0mph and got progressively inaccurate. Now it's highly inaccurate at town driving speeds and accurate at useless speeds higher up the range. Why you need to know it's accurate at 100mph i don't know, i'd rather centre it on a speed limit like 70mph. MUCh more useful.
Each to their own i guess?
Posted 3rd Nov 2010 at 15:56
bennn
You dont know what you are talking about. Putting lower profile tyres (and making the rolling radius smaller) causes you speedo to over read, so if it was unaccuarate before at 100mph (and standard they underead so you dont get done by speed cameras etc) it will only be more innacurate than before and read much lower. Unless as CW says you've fiddled with the needles making it accurate at 100mph and useless at any other speed
Or you arent running the standard 15" cyclones?
Cherry Red 306 HDI
Posted 3rd Nov 2010 at 16:17
Must be way off a lot of the time... mine still under reads very slightly according to sat nav etc, but is very close to perfect but i'm running 205/40/17's. (which are almost identicle over all diameter to 195/55/15)
Posted 3rd Nov 2010 at 16:16
mattgti6phase2
It reads accurate all the way through so not off all the time at all. As I said it's pretty much as before with the 55's as for knowing nothing about lowering the rear of a 306 when I said u can't adjust the rear my meaning was it's not like a front coilover you have to take it apart and adjust to your preference every time you want to go lower or higher. If we wish to p*ss and moan about a supposed in accurate speedo then I shall post an accurate video if needed?
5 x a 306 owner!
Posted 3rd Nov 2010 at 16:28
cwspellowe
Love to know what you've done to get the gearing so accurate Wink
Posted 3rd Nov 2010 at 20:14
mattgti6phase2
Me to Wink x
5 x a 306 owner!
Posted 3rd Nov 2010 at 21:41
berger
Hes looking at the KMPH instead of the MPH clocks.... LOL
Posted 3rd Nov 2010 at 21:51
mattgti6phase2
I must be. And also must be wrong because you say so. Oops my fault
5 x a 306 owner!
Posted 4th Nov 2010 at 04:38
oecken
i think if you understood the gravity of what was said then perhaps you would understand that it hasnt just "happened" and its suddenly amazingly accurate, more so than with the previous tyre size.... Roll eyes
Posted 4th Nov 2010 at 13:28
mattgti6phase2
As previously said I'm wrong my car is wrong as is my speedo, as said if I'm doin 30 I'm doin 30 if I'm doin 50 I'm doin 50 simples Smile
5 x a 306 owner!
Posted 4th Nov 2010 at 15:39
bennn
Yeah its f*cked, id scrap it
Cherry Red 306 HDI
Posted 4th Nov 2010 at 17:42
cwspellowe
Regardless of how sarcastic you want to be, and how O/T this is getting, the speedo works off a cog on the final drive of the gearbox. As such it works off a ratio to the rotational speed of the wheels.
Changing tyre profile affects the speedo by making the VSS/speedo think the outer circumference of the wheels are turning at the same speed, yet in actual fact the circumference of the wheel has changed and the distance covered is no longer in proportion with the speed the wheel is rotating, hence why the speedo becomes even more inaccurate as the gearing is set up based on the radius of a 195/55/15 tyre.
Like I said earlier, to make the speedo more accurate you either need to adjust the ratio between final drive and VSS, adjust the resistance of the circuit in electronic speedo cases, or what's more likely play with the needle til you "think" it's more accurate when in fact it's zero'd in at one certain speed and just as inaccurate at others.
Assume the speedo is centred at zero to begin with, with a 10% mechanical error. At 30mph indicated you will be travelling, for instance, 27mph. 10% underreading.
Zero the needle at 100mph, and at 30mph you will have the inaccuracy of a speed approx 70mph (100-30) so in fact you could actually be doing 37mph (10% of 70mph, overreading as working backwards from 100mph)
Of course those figures are based purely on guesstimation, for example you may not have centred it at 100mph, but you get my point. Like I said i'd love to know what you've done Smile
x
Posted 4th Nov 2010 at 17:50
