Author Subject: 406 brembos and 307 hdi 302 discs
teo79
Just bought some 406 brembos for my gti6 thinking of using 307 hdi 302mm discs will they fit?
tjones
Posted 1st Nov 2010 at 04:42
lotek
doubt it,
the 306 caliper mounting points wont allow a 300mm + disc to fit No
Posted 1st Nov 2010 at 13:11
bellcp306td
they will work with 206 180 / 307 110 HDi discs but they Sequel! like a pig.
If you want Brembos on your 306 you need to speek to Ash
Where did the road go!
Posted 1st Nov 2010 at 18:16
Xantia V6 discs work but they also squeal and are really heavy. Tarox G88 discs seemed to stop them squealing on a friend's car, but I went down the renaultsport 310mm route before buying any. It was a guaranteed solution to work and did loads better than the 406 brakes.
Posted 1st Nov 2010 at 22:26
teo79
Well ive already got the 406 calipers test fitted them last week against the gti6 disc it sat off centre and looked small in there im confident decent discs and dpads will eliminate any squeal providing i can find the right disc to fit
tjones
Posted 2nd Nov 2010 at 00:20
cooper666
if you figure it out your a Wizard
clio r27
ps3 id:cooperkloe
Posted 2nd Nov 2010 at 01:54
Teo they don't unless you have very grooved discs. Do a proper search on here as its been looked into a lot. Alloy belled ones would work too and cut the huge weight of the xantia v6 ones.
Posted 2nd Nov 2010 at 01:55
teo79
Ill look into it more before i go any further might give skip brown a call tomorrow see what they say.
tjones
Posted 2nd Nov 2010 at 04:19
bellcp306td
the RC Brembos are way better
Posted 2nd Nov 2010 at 15:15
I've got 406 Brembos with Tarox G88's - they do still squeal, but not nearly as bad and only under light braking.
If you're going to pour money into anything, don't make it a set of 406 Brembos.
Posted 2nd Nov 2010 at 17:42
bigbear
if wanting to use renault sport brakes is there a certain model or year that is better or does it not matter as will need to make a bracket up anyway? and will they then fit under cyclones or still need 16+ wheels
Posted 3rd Nov 2010 at 02:34
bellcp306td
You will need 16's all the RS brembos are the same the better modles have red ones.
Posted 3rd Nov 2010 at 20:25
teo79
Im sticking with the 406 brembos as ive already bought them. Took some rough measurements today and with the aid of a billet steel bracket and a 25mm spacer behind my 17 inch oz titans i may be able to use the original 406 305mm discs! Watch this space.
tjones
Posted 3rd Nov 2010 at 22:27
lotek
teo79 wrote:
with the aid of a 25mm spacer behind my 17 inch oz titans i may be able to destroy my wheel bearings.
Posted 10th Nov 2010 at 16:07
cooper666
^^LOL ^^
clio r27
ps3 id:cooperkloe
Posted 10th Nov 2010 at 18:59
