displaying posts 1 to 2 of 2
Author Subject: Gear Linkage Bush Problem
cornish_pug
Hi guys i'm not sure if this is ment to be like this Unsure should there be a lot of play in the bush for the main rod which comes from the bottom of the gear stick to the gear linkages, is this where my rattle comes from at high revs? Just seems to be a lot of play in this joint which i've attatched a picture below.
cornish_pug has attached the following image:
Team Diesel
Posted 31st Oct 2010 at 23:39
teo79
Hard to tell from the pic if you suspect it change it ive seen new linkages and bushes on ebay dont let it get to the point of forcing it in to gear!
tjones
Posted 4th Nov 2010 at 02:14
