Author Subject: injectors please help
norfolkboy01
hello can any1 on here help me i ve got a 306 rallye and its runnin like a bag of shit i have tried the screwdriver trick nd listined at the injectors 1 nd 3 are fine but 2 nd 4 are knockin and u can here it threw the screw driver can some one help me please lol
alex savory
Posted 31st Oct 2010 at 21:09
norfolkboy01
can ny one help me please
alex savory
Posted 31st Oct 2010 at 21:30
if you noticed a difference between some then i would try to swap them for known good ones on them 2 cylinders, ideally someone close to you with a gti6 so you can try before you buy
Posted 1st Nov 2010 at 00:10
mr swampy s16
**BAD SELLER**
Or swap the good ones with the bad ones.
If the problem moves then you know its the injectors, if it stays on the same two cylinders then you know you need to start looking at wireing etc
Posted 1st Nov 2010 at 00:51
norfolkboy01
ok thanks ny other advive wud still help im at a dead end lol
alex savory
Posted 1st Nov 2010 at 02:35
tbh there is no advice to offer.. it is a case of swapping debatably-bad ones for known good ones, or you need to be checking wiring to each injector if it's staying the same cylinder - or other issues..
Posted 1st Nov 2010 at 03:49
ryangti6
Unplug the injectors one by one with the car running and see if any of them either dont make a difference or make very little difference, this should help identify the bad ones if it is an injector problem.
Ryan
Posted 1st Nov 2010 at 06:45
