Author Subject: gearstick shaking?
denwar
dont think its a driveshaft, as they were striped ,cleaned and re greased when i put engine in at january, possible bottom engine mount ??? no shake through the steering, no knocking, only does it at a certain rpm when engine is under load, got worse since last week, shakes the whole front of the car ? what you guys think ?
denwar
Posted 28th Oct 2010 at 23:53
:: blade ::
I get the same with mine, im putting it down to bottom engine mount Smile
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 28th Oct 2010 at 23:54
denwar
pain in the hole, iv bought a powerflex mount off the bay, maybe thatl sort it.
denwar
Posted 28th Oct 2010 at 23:58
most likely to be an inner CV joint or an engine mounting.
re-greasing them does nothing to tighten up any wear LOL so don't discount them.
Posted 29th Oct 2010 at 00:04
denwar
short shaft was new, and drivers was nice and tight when i fired them in, its runin a bar of boost the now, soim hoping its just killed the bottom mount, it was a diesel mount i had in it, was wondering if anyone had the same prob, just trying to narrow it down to a shaft or mount???
denwar
Posted 29th Oct 2010 at 00:07
diesel mount is the same.
Posted 29th Oct 2010 at 00:34
denwar
0ut 2.1 td its a 65 shore rubber thats used for that, so its bit stiffer than a 6 mount, obviously not stiff enough.
denwar
Posted 29th Oct 2010 at 01:50
