Author Subject: Diesel gearbox on a GTi 6?
rich306
As above, been pondering about this for the last few weeks thinking about the different type of ratios on the 5spd Diesel gearbox and the 5spd Xsi Gearbox which i have to put on the engine when it goes back into the car.
Just wondering whether anyone's experimented with the two boxes say- Diesel GB with the 5th spd xsi ratio, or the xsi box with the 5th spd diesel ratio.
I was just thinking whether it would improve on the timings made when going up through the gears??
Anyone tried this?
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 26th Oct 2010 at 12:07
lotek
just put a 205 gearbox on and be done with it
Posted 26th Oct 2010 at 12:52
rallyeash
depending what you are using the car for. if its just a road car then leave the 6 speed in it, if its a track car then a 5 speed shorter box could improve things, but it depends on what track you are regulary doing and if its better suited
309 3dr K20 Type R
Posted 26th Oct 2010 at 13:41
rich306
Ok, i dont have a 6spd box and don't intend on doing so, the car will progress to be used more and more on track hence why i'm using the 5spd.
Lotek, care to delve more into your outburst on a 205 box? any reason?
- Top Tip!!!
Posted 26th Oct 2010 at 17:43
rallyeash
the 5 speed diesel box imo has too long ratios and i wouldnt fit it to a 6 engine
1.9 205 box or the 5 speed mi16/s16 box is the 5 speed box to go for.
either way requires buying a gearbox.
309 3dr K20 Type R
Posted 26th Oct 2010 at 17:47
rich306
Something to save up for then i guess, i'll stick with the xsi one until i have the money to fork out on one Smile Thanks for the help and advice, shall take that onboard.
- Top Tip!!!
Posted 26th Oct 2010 at 21:36
