Author Subject: Draining petrol
vernam616
Currently in the process of breaking a 6, however got the problem of draining the fuel
Whats the best way? when i lifted the fuel pump out, the petrol was almost at the top am i right in thinking theres a full tank to drain?
Dan
Audi S3 Black Edition
Posted 25th Oct 2010 at 00:51
jimmyrallye
cordless drill 7mm drill bit and a washing up bowl well maybe 2LOL
Posted 25th Oct 2010 at 02:37
chris with a pug
you could disconnect the coil packs, put the fuel line in a bowl and turn it over til its empty
Posted 25th Oct 2010 at 02:41
smegal
Hammer a screw driver into the tank.
You could take the pump out and syphon it out but it takes ages.
Ex SC-6
Now in a Megane R26
Posted 25th Oct 2010 at 03:09
blaze wip
Depends if you want the tank kept useable? Tbh, if your breaking the car its not that much hassle to drop the tank and empty it from the filler neck.
Be warned though when you tip the tank up, the fuel can and most probably will go everywere! LOL
mechanical_repairs wrote:
i feel like giving her a good dry bumming session.
Posted 25th Oct 2010 at 03:17
vernam616
Dont forget this tank has potentially 60L of fuel in it, i think ive found a method on how to make a homemade syphon
2L bottle
drill hole in cap and wedge pipe in the top, tape it up so it seals
put the pipe in tank at fuel pump point
squeeze bottle then let go, gravity should do the rest
do that 30 times, each time connecting a funnel onto my rallye LOL
Posted 26th Oct 2010 at 02:07
jonnie205
drill a hole in the tank, best way
Posted 26th Oct 2010 at 02:14
smegal
Don't make a seal on the pipe. As the fuel displaces the air in the bottle it will make the pressure go up.
Ex SC-6
Now in a Megane R26
Posted 26th Oct 2010 at 02:42
vernam616
Thumbs up
Posted 26th Oct 2010 at 02:54
funkymonk
Why not just put the fuel pipe in your container and put 12v straight across the pump?
There are only 10 kinds of people in this world, those that understand binary and those that don't...
Posted 26th Oct 2010 at 18:19
anth
Ive syphoned it before.
Posted 26th Oct 2010 at 18:57
bennn
i syphoned it, you wont get it all, but the rest will remain in the tank until you remove it then you can just turn the tank on its side and empty the rest into the bottle.
I did swallow a fair bit of fuel/fumes as it took me several go's, this gave me a headache and very smelly burps.
Cherry Red 306 HDI
Posted 26th Oct 2010 at 20:08
joevts
Dan
you mean at the top of the pump or the top of the tank? when i got a pump from the scrappy it was full of fuel, i think they just retain it in the outer casing for some reason. try dipping a stick in the hole where the pump was to get some idea of how much is in. those tanks are hard enough to manouvre with 5 litres in never mind 50.
Posted 26th Oct 2010 at 22:49
vernam616
Dan
I lifted the pump out under the rear seat
+ with the homemade syphon, you dont put your mouth anywhere near
Wink
Posted 26th Oct 2010 at 22:51
309btcc
**DODGY SELLER**
old fuel pump 2 pipes run 2 wires from it to a battery and 1 pipe thru the filler neck into tank other into big can connect the wires and it will pump out all the fuel
Posted 31st Oct 2010 at 20:39
cress87
Just park it up near a travellers site for a couple of hours and let nature take it's course. Wink
Posted 31st Oct 2010 at 20:42
