Author Subject: Door Trouble...
hudson603
Hi All,
I had a creaking problem a while ago with my pass side door so sprayed up the check strap with WD40 and it seemed to do the trick...
Now I've got the Pass side door, not creaking but "clunking" twice if the door is opened to the extreme, off today so had a quick look and got the camera in the door and this is what it found...
Is this fixable or do I need to be on the lookout for a new door?
Posted 20th Oct 2010 at 15:35
loftlex
strangly enough i had this problem,, tighten the bottom nut as tight as it will go,, then get another nut and put it on the top and you should be fine Smile
if the thread has snapped you just need another arm,
GTI wanna be Sad ---In a puff of black smoke and a whistle,,, i was gone Smile
Posted 20th Oct 2010 at 17:15
blondie
Dirty Diesel Pro
New check strap time Wink
9181 73 for Phs 1-2
9181 E5 for Phs 3
A 306 EnthusiastWink
phillipm wrote:
But diesel is the devils fuel Devil
Ps3 IDRazzhils306
“S-H-I-T-H-O-L-E.. Shithole!”
Posted 20th Oct 2010 at 17:50
hudson603
One of the E5 variety is on order and should be able to collect it tomorrow lunchtime, I've got the door card off now ready for the change and I actually quite like it without!?! What am I thinking?!
Posted 20th Oct 2010 at 19:52
hudson603
All sorted, easy enough did get absolutely covered in grease though, sadly the t-shirt I was wearing didnt make it...
Thanks blondie for the part number info! Thumbs up
Posted 22nd Oct 2010 at 03:55
