| Author | Subject: Engine temp around 75-80! |
jakeypoo
Regular Location: Kent Registered: 22 Sep 2010 Posts: 318 Status: Offline |
Is that temp about right for this cold/wet weather, thats moving at speed e.g going along the motorway at night! It seems a bit low but im new to Peugeots so not too sure! |
daler5
Newbie Location: Benllech Registered: 17 Sep 2010 Posts: 29 Status: Offline |
mines about the same but will go just over 90 untill the fan kicks in when sat in traffic |
chas
Seasoned Pro Location: Warwickshire Registered: 31 Oct 2007 Posts: 1,468 Status: Offline |
The chances are that it will need another thermostat. Ensure you get it with a new seal and that it is fitted correctly.Although (including me) will live (well, I lived with it) with the temps going like so. ________________________________________ Ex Owner of 2000 Phase 3 306 GTi 6 China Blue - You shall be missed1974 Triumph Stag 1989 Peugeot 205 GTi 1.6 2003 Alfa Romeo 147 JTD Lusso 2005 Mondeo Ghia X 3.0 Estate LPG |
mikebee
Regular Location: Northampton Registered: 17 Aug 2010 Posts: 122 Status: Offline |
Mine's the same. Just rebuilt the top end and fitted a new thermostat and radiator.On dual carriageway it sits just below 80 and round town goes up to just under 90 in traffic. |
bennn
Seasoned Pro Location: Shrewsbury Registered: 05 Sep 2008 Posts: 2,705 Status: Offline |
Its normal, im guessing you've had some sort of VAG where the temperature sits bang on 90 all of the time.________________________________________ Cherry Red 306 HDIChampionship White Integra DC5 Type R |
honestly3k
Seasoned Pro Location: Berkhamsted Registered: 06 Apr 2009 Posts: 2,390 Status: Offline |
Normal matey!________________________________________ ''Oh, it does handle like a golf!'' Why drive a Golf....when you can drive a GTi-6? |
heliosphan
Senior User Location: UK Registered: 14 Sep 2007 Posts: 950 Status: Offline |
Completely normal if you're moving at a constant speed and it isn't mid July in Spain! |
allesclar
Seasoned Pro Location: Sheffield Registered: 17 May 2009 Posts: 4,254 Status: Offline |
ITS NORMAL DONT BUY A NEW THERMOSTAT.will hover around 90 in traffic but yes that temperature is fine. ________________________________________ Team allesclar ® |
jakeypoo
I had a mk4 astra Sri before which would pretty much sit at 90! I thought it would be normal, just thought I would double check! |
mabgti
NV motors Location: Bham tunnel @7400rpm Registered: 28 Aug 2003 Posts: 9,127 Status: Offline |
as echoed.. gti6 run at 79-85 degrees in normal conditions..________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
kit
Seasoned Pro Location: Location: Location: Registered: 22 Jan 2009 Posts: 2,394 Status: Offline |
Just jumping on the band wagon here. You don't need a new thermostat, it's normal temp. Just reiterating, it will hit 90+ sat in traffic or the drive through MacDonalds, which is when the fans will turn on and bring it back down ![]() ________________________________________ Racing driver, fighter pilot, astronaut, compulsive liar. |
