Author Subject: Help with fuel regulator
pug-gti-6
I have taken a fse power boost valve off my six and need help with where the pipe from the inlet manifold goes. am i right in saying it goes to the regulator on the fuel rail. this is pretty urgent as i need to get the car running today.
"if in doubt flat out"
Breaking 206 gti
Posted 19th Oct 2010 at 15:17
Rich E Forum Admin
Correct, it goes to the standard regulator.
Posted 19th Oct 2010 at 18:49
mabgti
NV motors
right... you are scaring me with your knowledge of this... and your diesel problem
The FSE power boost valve uses a regulator dummy in the standard fuel rail which directs fuel to the Power Boost Valve. So when removing the FSE you need to remove this and fit a standard 3bar fpr in its place connect the vacuum pipe to the inlet manifold.. Have a look at some of the standard gti6 engine bay pictures!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 20th Oct 2010 at 04:36
