| Author | Subject: 6 Cam Pulleys for xsi |
benn25
Regular Location: In the woods Registered: 14 Jan 2009 Posts: 303 Status: Offline |
Looking to change cam pulleys in my xsi to 6 version. Will these fit straight in? When I get the 6 cams will it fit straight in or will i have to tinker. Plus is there anything else I will have to replace with 6 items. Cheers. |
exhaust pulley hub is the same as the gti6,and the gti6 uses identical ones inlet and exhaust.the outer pulley is the same on all of them. gti6 cams would go straight in, but you have an oil feed on the end of the exhaust cam that needs to be plugged. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
benn25
Many thanks welshpug. Your a gentleman and a scholar. |
benn25
welshpug! wrote: exhaust pulley hub is the same as the gti6,and the gti6 uses identical ones inlet and exhaust. the outer pulley is the same on all of them. gti6 cams would go straight in, but you have an oil feed on the end of the exhaust cam that needs to be plugged. Is the oil feed you talking about the vacuum pump for the brake servo??? |
