Author Subject: knocking
5hane_222
after rebuilding the bottom end with a new crank, uprated main and big end bearings ive got a knocking noise coming from the bottom end.......the oil chain is abit slopy could this be it? how much play should i have in the chain?
Posted 17th Oct 2010 at 17:20
5hane_222
oh its only on tick over, no noise when its reved up even just slightly?
Posted 17th Oct 2010 at 17:22
what's the oil pressure like?
there's usually some play in the chain, did you remember the spacer plate that sits between the pump and the block?
was the crank measured and the clearances checked?
Posted 17th Oct 2010 at 17:38
5hane_222
Havnt got a pressure gauge, thought they only had an oil temp gauge?
Yeh I remembers that, got the sump off and there's about a good inch play in the chain and the pumps working fine, what torque settings have you got for the crank main and big end bolts?
Sounded weird as if something was tapping on the sump to get out!!!!
Posted 17th Oct 2010 at 18:31
5hane_222
What do yu lot do t take the tension up in the oil chain as there a few clear marks of the chain rubbing on the cover?
Posted 18th Oct 2010 at 01:58
5hane_222
Which clearances?
Posted 18th Oct 2010 at 02:15
5hane_222
Which clearances?
Posted 18th Oct 2010 at 02:04
bearing clearances.
Posted 18th Oct 2010 at 03:03
5hane_222
Which Way?, is there any play left to right in the con rod on the big end?
Posted 18th Oct 2010 at 23:02
5hane_222
Sorted it was the chain to loose. Does no where do a thicker plate to take this tension away?
Posted 24th Oct 2010 at 18:51
