Author Subject: 88mm Crank + S16 Internals
craigm
Hey
Ive searched around and yes, found shit loads of threads relating to this but found alot of yes and no answers so hopefully i can clear this up:
If i used the 88mm Crank from the XU Diesel engine, and the Rods and Pistons from the S16 engine in a Gti6 Block and Head, would there be any machining required to the pistons?
Does anyone know what the max Valve clearence would be and what safe lift @ TDC you can run with this?
Thanks, and sorry if i missed a crucial post whilst searching
6 Project Coming Soon Smile
Posted 12th Oct 2010 at 20:20
quite a bit of info here though nothing 100% concrete Smile
doesn't have to be a diesel crank btw, just a 1.9 8 valve or 16 valve petrol will do too.
Posted 12th Oct 2010 at 23:11
craigm
Cheers pal, ill have a good nosey Smile
Posted 13th Oct 2010 at 02:27
standard bore is 86mm btw.
Posted 13th Oct 2010 at 03:14
craigm
cheers!
Posted 13th Oct 2010 at 17:19
